avatar_Tophe
Martokker D.XV
Started by Tophe, February 28, 2010, 06:05:03 AM
Tophe, good to see your creative juices are still flowing!  :thumbsup:
Here is another idea that you might like.
"I might like"? No, I DO LOVE :wub: :wub:
Alas, building this is above my scratchbuilding abilities. But thanks for this drawing enrichment possibility! :thumbsup:
Those are some neat ideas you have there, Tophe ! Great stuff !
She walks by on her way to be a model...
The first putty and sanding has been performed, then... once again! as usual...
Going on...
The poor connection between D-XXIII parts will require more work...
This new TT-tail model is taking shape...
Quote from: Tophe on February 28, 2010, 06:05:03 AM
(the RS thermoformed canopy frightens me a little, but I will see).
Now that's the point I am, alas. What a hell! (in French: "Pu-rée !") How to turn this into a canopy?! I don't even see where is the front and the rear... :huh: >:( :huh: :blink:
That is very coooooool :mellow: What scale is it I got lots o extra canopies laying around.
I just did my first vac-form canopy Tophe, so I know how you feel. The key is to go very slowly and in very small bites. Make you first cuts well away from the canopy frame and then work towards it. Stop when you are still a visible distance away from the frame, and then go to sanding. Sand a little, look, check-fit, sand a little, look, check-fit, etc, etc.... Do NOT lose patience and try to do too much in one bite! If you start to feel like that, put it down and walk away for a bit.
Quote from: sotoolslinger on April 06, 2010, 11:08:13 AM
Thanks! The scale is 1/72 but I don't think you should discard those canopies: I mean, my project is to paint it black, I don't need at all a clear canopy. If I fail in handling the thermoformed support, I will replace this with putty, simply, with a further step into whiffism... ;D
Quote from: Weaver on April 06, 2010, 01:43:15 PM
Thanks also! I will try to follow these advices, as much as my poor skills allow it. If I fail, I will replace this with putty, almost simply. Thanks again! ;D
WOW! now it looks like it could be a high speed racing boat. Lookin' good Tophe  :thumbsup:
Thanks, Black Ops, to find a 'reason'/explanation, other than my craziness...
Midway between a boat and a plane, this is an Ekranoplane, at last...
(Finished, according to my poor standards, just for fun of building)
That made me enrich also my P-38 fantasy gallery:
