avatar_Spey_Phantom
WHIFS found while Google-ing
Started by Spey_Phantom, March 23, 2010, 01:41:44 AM
found this Royal Netherlands Air Force F-22A Raptor  :thumbsup:
Found this at a site called http://rareaircraf1.greyfalcon.us/GREAT%20BRITAIN.htm
Maybe old hat on here but still looks good.
wow!!
There's some great ideas on that site. :thumbsup:
Quote from: PR19_Kit on August 16, 2011, 04:06:06 AM
It looks neat except the inner to outer nacalles aren't far enough apart, the props will hit each other
AH, but the outer nacelles are positioned about one foot behind the inner ones , so no problem.
The sound though is weird :rolleyes:
Mike Wren
#321
also, as I understand it, a standard Mossie (later marks?) could hit a target at the same range with the same amount bombs as a Lancaster could. All using 2 less engines and a lot less in the way of crew, materials etc... surely less is more...?  ;)
Quote from: PR19_Kit on August 16, 2011, 01:08:32 PM
Quote from: JayBee on August 16, 2011, 12:26:01 PM
Won't it sound just like a Lancaster?
Nah! The Lancs props do not overlap, whereas that Mossie's do.
Jim
First: I really like the look of this Mosquito variant  :thumbsup:.... but...  :unsure:
... the turbulence created in that lay-out would cause a terrible, & probably fatal, vibration problem. :blink:
:banghead:
Too, much, serious, talk.  Must, interject, more, whiffery...
AVRO 10-ENGINED LANCASTER PROJECT
(from the same site)
..... Well the problem could be fixed by making the wings longer & separating the engines so the blades don't overlap. ;)
Now fitting longer wings, there's a novel idea :wacko:
Quote from: JayBee on August 17, 2011, 09:29:35 AM
Hm, yes, I could relate to that............ ;)
Do you think this longer wings idea will catch on?
Quote from: lancer on August 17, 2011, 03:00:07 PM
No chance, it's WAY too far out in left field............  ;D
