avatar_Fulcrum
Praticallity be darned
Started by Fulcrum, June 30, 2010, 10:39:53 PM
Quote from: dy031101 on July 02, 2010, 11:17:45 AM
Quote from: Cobra on July 02, 2010, 10:56:18 AM
How About a Box Missile Launcher mounted on the Tail of Either a B-52 or an Avro Vulcan Bomber? don't know if it's even been Considered but thought i'd ask. :cheers: :cheers:Dan
There, IIRC, used to be talks on fitting Stinger missiles as a tail armament of a B-52......
Wasn't that part of Dale Brown's EB-52 Megafortress?
dy031101
Quote from: joncarrfarrelly on July 02, 2010, 12:21:38 PM
Then you'd be dealing with "old-style" (ladder and tube frame) sports car designs as most went to uni-body designs some time ago. ;)
Doh!  :banghead:
What about sedans and their coupe derivatives?
To-do list here
Quote from: Mossie on July 02, 2010, 06:20:03 AM
Early Lotus Esprits & Lamborghini Countachs might suit that, all angles, possibly the Delorean as well.  Lenny did a Lancia Stratos as a fast strike vehicle a little while back.
Quote from: Weaver on July 02, 2010, 06:31:37 AM
Years ago I did a Car Wars car with the body of a Lamborghini Countach and the Vulcan cannon from the 1/32nd Revell Starfighter on the side.... :wacko:
I'm thinking a lighter version of how truck chassis got turned into armoured cars, which may or may not retain the factory body.  :wacko:
Maybe for internal security use.
So that would be a "sporty" Beaverette then?  ;D
http://en.wikipedia.org/wiki/Standard_Beaverette
Quote from: dy031101 on July 02, 2010, 04:28:44 PM
Doh!  :banghead:
Same situation, and unibody construction has actually been used even longer on sedans and coupes,
starting in the 1930s with Citroen and Lancia.
dy031101
#19
What say we think up another two-gun tank design?  Okay maybe not a modern-modern type to fit into late- to post-Cold War era but a late-WWII type serviceable enough to last into the Cold War era?
Take a gun that was powerful against tanks but fired a rather useless HE round (for example, KwK 42) and put it in the turret; take a reasonably-compact infantry gun/howitzer that has a much more useful HE capacity and put it in the hull.  Try not to make it too heavy though- in fact, I wonder if keeping its weight within the top range of a medium tank would be possible......
Might be difficult for me, I keep on thinking of something asthetically based on the Panzer III (with gun arrangement similar to that of Churchill Mk.I)......  :banghead:
To-do list here
I've occasionally toyed with the idea of an M3 Medium Grant/Lee tank with two sponson guns.  Would make things rather interesting on the North African battlefields.  ;)
How about a tank-destroyer with an AT gun in the hull and a turret with an MG and a high-angle, low velocity gun (like those 37mm guns in French light tanks) to keep infantry teams away? It could even have a 37mm pom-pom  :wacko:, but that weapon's got a significant inboard length..... Alternately, the turret gun could be a small breech-loading mortar in the 51-60mm range.
dy031101
Keeping a record of an idea here and maybe hoping for some critique:
  • turret inspired by either Panzer III or Strv 74
  • hull inspired by Excelsior infantry tank
  • KwK 42 gun and co-axial MG in turret, infantry howitzer of maybe 75mm calibre in hull
To-do list here
anthonyp
Quote from: GTX on July 02, 2010, 01:25:12 PM
Nah, that 'shroom experience of a book had the Old Dog flying around with AIM-120 "Scorpians"
I exist to pi$$ others off!!!
Caveman
practicality be darned?
ok
a big gun monitor built on a hovercraft?
Quick to intercept any approaching threat... recoil can be a bit of an issue...
secretprojects forum migrant
Quote from: Caveman on July 26, 2010, 12:18:45 AM
ok
The ultimate "shoot and skoot"  ;D ;D
tigercat
Submersible Aircraft Carrier
James
Quote from: joncarrfarrelly on July 02, 2010, 11:58:29 AM
Grumman Design 143 Bushfire rear-defense missile system intended for the Martin P6M-2 Seamaster.
Good stuff. Had no idea about that proposal.
dy031101
Quote from: anthonyp on July 25, 2010, 06:25:50 PM
I thought the Old Dog was initially using unguided shotgun-like flak rocket launcher for a tail gun.  ;D
To-do list here
dy031101
What if the SMK and the T-100 were put into production for Heavy Tank Brigades solely responsible for parade and defense of Soviet seat of power?  How would they have been modified/improved to remain competitive armament-wise?
And for a slightly less-crazy scenario, what if Finland captured more T-28s and figured they can make those tanks combat-worthy better than the Soviets ever could?
To-do list here
