avatar_Radish
F8F Bearcat
Started by Radish, July 16, 2010, 12:01:42 AM
That turtledeck version is gorgeous  :wub:
RotorheadTX
Enter the Shacklecat......  :wacko:
Just getting started....in my hotel room....sorry for the naff photo (crappy phone-cam).
Quote from: Doc Yo on July 16, 2010, 11:26:01 AM
Give it a spinner. Bare propellers on anything that does more than 200 mph are an offense against the
Creator.
Quote from: Radish on July 17, 2010, 02:03:06 AM
Spinners certainly look more aesthetic...certainly something to consider.....especially when tipped with flight or squadron colours.
I did this quite a few years ago, nothing really whiff about it except the Tempest Mk.II spinner I put on it.
That spinner improves the Bearcat out of all recognition.  :thumbsup:
I wonder why Grumman didn't try it? Perhaps it would have blocked off the cooling air?
I've read somewhere that Grumman did test a spinner on the Bearcat, but the results were (at least officially) that it didn't improve the overall speed by very much (mind you, I could have read that about the Tigercat  :banghead: ).  I don't quite follow that because the Bearcat 'Rare Bear' which was fitted with a Sea Fury type spinner, had the absolute speed record for a piston powered aircraft for a long time, somewhere around 520 mph IIRC.  There are a few others used in the Unlimited class at Reno that have A-26 type spinners fitted.
Quote from: kitnut617 on September 13, 2011, 04:08:08 PM
Exactly! I built a model of 'Rare Bear' in the Miss Smirnoff white and blue scheme with the spinner. I'd post a piccie if it wasn't one of the casualties, just need one gear leg though.
The F7F prototypes and early production aircraft had spinners, however, I've never come across any
pictures or reference to the F8F being officially tested with a spinner. The F7F spinners were dispensed
with as unnecessary. Anyhow any speed increase on the F8F would probably have been extremely minor
and not considered worth the expense.
There are photos of at least one civil owned F8F-1 that was fitted with a spinner at some point in its life.
Also Rare Bear isn't really a good example as, along with a spinner, it was equipped with an R-3350
set up for max power production at low level.  ;D
I think it was the F7F I was reading about Jon, which I've found  Mosquito spinners works very well for if you want to convert one.
Yeah!, I realize that Rare Bear had the R-3350, but the jist of the post was that the spinner helped it get it's speed.  It was after seeing Rare Bear back in 1996 at the Reno races that I built the model.
Quote from: joncarrfarrelly on September 13, 2011, 05:16:54 PM
Plus a few other changes, like lopping 2 feet off each wing, and fitting a canopy slightly smaller than a wash basin!  ;D
But it looked great.  :thumbsup:
Quote from: PR19_Kit on September 13, 2011, 02:56:11 PM
Got to agree, makes it look even more lovely IMHO  :wub: I may retro fit my BPF one with one
Quote from: PR19_Kit on September 14, 2011, 12:15:34 AM
That's a matter of opinion.  Personally, I'm against converting classic warbirds into racers.  If you want a racer, get one built and stop mucking about with aircraft that are rare enough as it is.
"Visit Scarfolk today!"
According to Squadron's F8F Bearcat in Action, the original wing design had it so that the outer two feet of the wing would detach itself when under very high 'G' loads with the idea being that it would save the rest of the wing from catastrophic failure and then for the aircraft to be able to get back to the ship.  Apparently the aircraft flew quite well with either one or both the tips gone but the USN didn't like the idea so the wing structure was altered so the wing tips didn't shed, and all the racers have done is remove this part of the wing.
There's some photos of some test aircraft with detached wingtips in the 'in Action' book.
Do I read this correctly?    This gentleman  has   SHORTENED  the wings of an aeroplane?  This seems to be rather out of character.
Quote from: Rheged on September 14, 2011, 06:27:48 AM
No, not Kit  -- :lol:  the guy who built the real Rare Bear
