avatar_G.Marcat
Mix F-104 and SR-71 (1/48) two engines, a delta wing.
Started by G.Marcat, July 24, 2010, 09:34:35 AM
G.Marcat
Today was a busy day.
Few moments ago I applied the "engines" at the F-104 DELTA WING.
I used the RB-199's engine exhausts taken from a Tornado ESCI.
The engine nacelles are two center line tanks taken by two Phantom ever from ESCI.
Here's how it comes out the work:
G.Marcat
Cobra
Very Cool :mellow: Tell Me that Plane Doesn't look like something from Thunderbirds! Have you Decided on Paint & Decals Yet? Dan
anthonyp
This is so awesome its... AWESOME!!!!
Now I know what to do with those F-104's I have no idea what to do with.  And this sooo is gonna be an orbital fighter for me.
I exist to pi$$ others off!!!
G.Marcat
Quote from: Cobra on July 28, 2010, 03:54:23 PM
One idea was to complete the model as if it were in use at the Italian Air Force (F-104  and the engines from Tornado: Italy has had both models).
Cobra
Have you ever seen the Movie 'Blue Tornado'? the Heroes flew F-104S's!
G.Marcat
Quote from: Cobra on July 28, 2010, 11:59:03 PM
Not, never heard of this movie.
tanktastic43
On hols at present, trying to catch up a little.
This IS going to be good!  :thumbsup:
tt43.
arkon
i know the drawing dont show it , but hows the under side look?
G.Marcat
#25
Quote from: arkon on July 29, 2010, 03:49:33 PM
I presume that the bottom of the wing there is the air intake.
I searched in the computer but have not found other drawings to explain something.
Looking with Google I found a Chinese page http://tieba.baidu.com/f?kz=301461824 where there is the my F-104: it's called XX-201
G.Marcat
Something done also today:
Initially I was undecided about where to put the air intakes: over the wings? Under the wings?
Sincerely I liked the idea of placing them above the wing in the area that could be seen but at the end I made the choice , to apply the air intakes under the wings because the risk of to do a bad work in a place where all is visible (over the wing) was not acceptable.
As a basis for the operation  I used the two pieces of halves from the the F-104 Monogram as donor kit.
Adapting  the Monogram  shells to the previously glued pieces took a little of plastic surgery.
This is the result obtained.
Now I have to smooth the connection of the two pieces (the connection is not clean at the 100%) but the hardest part is done.
G.Marcat
#27
Another problem:
From the engine exhaust can be seen inside the engine compartment and wing ...
With another piece taken from the donor model Monogram F-104
I solved the problem:
I'm not happy with the result but the space between the engine nozzle and the wing does not allow too much freedom.
Cobra
arkon
it looks good , below the wing is best for the intake, looks smooth.
