avatar_Spey_Phantom
Calculus anti-Shark submarine Mk.II
Started by Spey_Phantom, September 11, 2010, 10:10:33 AM
yes, i still got the Tintin bug in me (like every crazy Belgian)  ;D
but instead of an aircraft (planned on building a prototype A-7J SuperSLUF), i decided to have a change of pace and build a Submarine (allongside a Syldavian LA-5FN to fight my bordurian 109  :blink:)
i plan to convert a 1/72 revell Me262B into a shark like submarine, the one from the Tintin stories was a single seater, with an oxigen supply lasting only 20 minutes, this version will be an updated one, with 2 seats and a longer dive time  :drink:
it is an experimental sub, so i think this qualifies  :huh:
here's a pic of the single seater from the comic book  :mellow:
and here's a pic of the me262, with its tail removed, she will hace a propellor fitted on the tail  -_-
oh, one more thing, i just decided to dump the Me262's standard canopy, and replace it with that of a matchbox Meteor NF.14 (kit comes with 2 canopies)
did a dry fit and it looks tons better  :wub:
last night, all the parts for the cockpit were painted up  <_<
this morning, they were put together  :mellow:
fuselage halves met....
no now comes the hardest part, closing up the bottom with plasticard, tons of putty and a lot of sanding  :blink:
and here's a dryfit test fitting of the Meteor NF14 canopy, looks a lot better then the standard me262 canopy, if i ever get a hold of another Meteor night fighter, i might use the canopy to create a 50's version of the Me262  ;D
Quote from: Nils on September 12, 2010, 02:08:42 AM
....and here's a dryfit test fitting of the Meteor NF14 canopy, looks a lot better then the standard me262 canopy, if i ever get a hold of another Meteor night fighter, i might use the canopy to create a 50's version of the Me262  ;D
How many would you like Nils?  ;D
I have VAST quantities of Matchbox Meatboxes up in The Loft.
here's a small update on the build  ;D
i just finished plating and putty up the gaps, when its dry i can begin sanding  ;D
also, the first 2 sharkfins on the tail have ben fitted, a few more will follow later  :mellow:
Arc3371
Wow, looks like a very interesting build
ok, one more update for today  :thumbsup:
the sub has been completly filled and sanded down, and all the sharkfins have been added.
the prop is currently drying (painted in copper/bronze).
if your wondering what those 2 drilled holes are on the bottom, well, im planning on putting it on a display stand (to be seen when its finished)  :mellow:
she's starting to look a lot like a shark  :lol:
Slerski
« Le MAGIC, c'est fantastique !! » [Sgt Vincent D., FAF armourer]
« Un Pétaf qui s'ennuie est un Pétaf dangereux... »
tanktastic43
Ed S
Green Dragon
Class build Nils! :thumbsup: That Meatbox canopy looks like it was designed for turning a 262 into the Tintin sub.
Paul Harrison
On the bench.
last night, i painted the first layer of white on the underside and i just finished applying the second layer.
tomorrow im gonna start on the black paint  :mellow:
the canopy does seem a bit big though, i think the sub looks more 1/48 rather then 1/72  ;D
pictures  ;D
