Super Missile Carrier Idea
Started by Cobra, September 18, 2010, 11:04:40 PM
Cobra
Hey Guys, What If The B-52 was Used to Carry a Modified Bomarc Missile or Other Missile to Within Range for a Surgical Strike? the Idea hit me while thinking about the Bomarc & The B-52. Think it would work? i was Thinking the Modded Bomarc could be used to Shoot down Soviet Bombers as they were Taking Off or In the Air. i was Thinking with Other Missiles,like Nike Hercules,Honest John,Etc. for Strikes Without Warning. What Say You? Thanks for looking.Dan
It would depend on the size and weight of the missile; try looking those up and see if they'll fit the B-52. The B-52 would also have to carry the guidance system; from what I remember, the Nike Hercules needed a pretty big radar set.
Archangel
You would be better off arming a B-52 with AIM-54 Pheonix missiles then a Nike Hercules. The Nike Hercules only had a range of 60 miles and either a 2,000 lbs HE warhead or a 2KT nuke. The Radar set to guide the missile and locate Russian aircraft needed a whole bunker to work from. The ground clearance would also have kept it from even being mounted ont othe pylons.
I was stationed in Italy to guard Nike Nercs back in 1984-1985. Here is a link wit hpictures to show you how big the system is.
http://nikemissile.org/Italian/italian_air_force_nikes.shtml
Jschmus
The Honest John was an unguided ballistic weapon, so it wouldn't be well-suited for air-to-ground use.  The B-52 already had the Hound Dog, the SRAM and later the ALCM.
