avatar_The Rat
Oh dear, Hyperscale does it again.
Started by The Rat, November 09, 2010, 05:52:58 AM
I have attempted to set the record straight, but I fear seeds of doubt may have been planted, you can see the awful thread here. Perhaps all concerned Whiffstorians should let the facts, such as they are, be known.
A Farley Fruit Bat eh??
Do they taste anything like their rusks?? ;D
Chris.
Dear oh dear, Hyperscale must be last bastion of the JMN if they've never heard of the Fruitbat.  :banghead:
Quote from: PR19_Kit on November 09, 2010, 07:38:06 AM
They have , this guy was a newbie. But when they disparaged the aircraft by saying it was a figment of the imagination, well, one can only stand so much, I had to jump in. The discussion has started.
dragon
Quote from: The Rat on November 09, 2010, 08:07:15 AM
I doubt that the fine folks at megalomaniacalscale have even heard of the F-86 Sabre!
Alvis 3.14159
That was a rather fun read, they really got into the spirit of things there!
Alvis Pi
raafif
Oh Boy !!!!!!!!
                  the best read & most laughs I've had from the 'Net for quite a few years ! :lol: :lol:
frank2056
I haven't seen the name "Fairley/Farley/Farleigh Fruitbat" since the good old days (ca 1998) of rec.models.scale.
Here's a highly accurate and detailed technical drawing I made, based on the tech specs listed on RMS. Notice the prominent relief tube just to the rear of the cockpit door...
Quote from: frank2056 on November 09, 2010, 01:59:49 PM
A fine representation of, I believe, the MkII, and certainly 'do-able', just have to accumulate the right parts.
Nick
May I point you all at the Farley Fruitbat Forum?
I was one of the founder members way back when.....  ;D
http://s7.invisionfree.com/The_Bat_Drome/
frank2056
Quote from: The Rat on November 09, 2010, 02:16:07 PM
I wonder if BdB would make one - after all, look at all those spats! I did forget to add spats to the tail wheels, though.
Surely it's a Mk I? The Mk IIs had a turbo-fan auxiliary jet and the one in the piccie is the early Pratt & Rolls CF23-D6 turbo-jet, you can tell by the shape of the cowling.
Quote from: PR19_Kit on November 09, 2010, 03:18:28 PMSurely it's a Mk I? The Mk IIs had a turbo-fan auxiliary jet and the one in the piccie is the early Pratt & Rolls CF23-D6 turbo-jet, you can tell by the shape of the cowling.
You could be correct, apparently some of the Mk Is were retro-fitted with the mahogany interplane struts in place of the teak. Okay, Mk I it is!
Oh............what an interesting concept......I've had a look on the website listed (as much as the webmarshall at work will let me........)....from what I have read its def not the prototype......
frank2056
The jet on the back is a surplus Jumo 003. An even number of engines means an even number for the prototype... The tilt-engine in the nose is movable because the engineers discovered that the prop would hit the ground as designed.
