Whiffs found surfing
loupgarou
Quote from: PR19_Kit on June 25, 2019, 08:00:25 AM
A bi-plane, tilt wing, double deck VTOL airliner with no fin at all?  :o
That's some 'advanced technology' alright.  :thumbsup:
From the first drawing, it seems to have a swing-nose too.  ;D
But fins that rotate WITH the wings?  :-\
Scotaidh
Quote from: PR19_Kit on June 25, 2019, 11:25:50 AM
Don't really need 'em in vertical flight up or down ... probably.  ;)
Well as long as you ALWAYS land vertically, then you can rotate the wings/fins/engines to stop the ventral fins from hitting the ground. That removes the rote-clearance limit on the size of the ventral fins, and, indeed, the four on this bird seem to be all the same size. Four small fins should be structurally lighter than one big one, since each will exert much less bending force on it's root. Of course the flip side is that four fins complicate the rudder control system too, but there's no sign of rudders on this one... :unsure:
I'd love to tell you the terribly good reason for mounting the fins on the engine nacelles, but it escapes me for the moment, as does the knowledge of what exactly is holding the front of the fuselage up when it's in VTOL mode... :o
Crystal Palace Aerodrome would be dead handy for Chris.
Quote from: Weaver on June 25, 2019, 10:44:56 PM
...what exactly is holding the front of the fuselage up when it's in VTOL mode... :o
Art.
zenrat industries  bootstrapium bladders in the forward fuselage, astern of the glazing. ;)
Awesome tech for 1898! :thumbsup:
Scotaidh
Quote from: zenrat on June 26, 2019, 01:45:29 AM
Art.
Oh - is that the invisible man's name?  He's very strong.  ;)
This is why it made me think of Ministry Of Space: the artist has done a splendid job of capturing the visual style of the era, without letting the fact that he has absolutely no idea how things actually work hold him back...
That was my very first thought on seeing the illustration  ;D
Was just wondering if it was in addition to, or instead of Croydon Airport ?  ;)
Technicalized street rods, posted on Twitter by Hobby Dude ( @BigHobbyDude ) here: https://twitter.com/BigHobbyDude/status/1147287111835328512
First one looks like it has two engines (possibly big block Chevys).  Could work for the current GB...
The problem with building such things in 1/24 or 1/25 is the scarcity of weapons in that scale.  Although that may change with the advent of 3d printing and shapeways..
The weapons on those do look a bit 'interesting': close to real ones but not quite.
This is also, of course, why outfits like Meng have started doing generic definitely-not-Landcruisers in 1/35th.
There are quite a few staff cars and pre-war supply trucks in 1/35th that would look good hot-rodded...
These look hot-roddable (all 1/35th):
(ICM 1/35th scale Benz top G4 (W31) )
(Just for a laugh...)
1/48th hot-rodder-fodder:
This one even comes with it's own guns!
Scotaidh
Very trusting officer, on that last truck.  :)
1/35th choppable trucks:
Hobby Boss GAZ AA:
Hobby Boss GAZ AAA:
There are loads more in the ICM range, plus Mini-Art do all the GAZ-AA/AAA/MMs as well. Zvezda do a GAZ-AA too.
My understanding is that the GAZ-AA truck is basically an early Ford design built under licence.
