avatar_GTX
The Fear and Trepidation GB (was Resin Kit GB)
Started by GTX, December 03, 2010, 08:59:23 PM
Merlin kits - it depends on the master.  Some of them are quite buildable but others are utter garbage, the aforementioned TSR2 being one.  However, it can be built.  I've seen at least 2 over the years.
"Visit Scarfolk today!"
Resin generally, Unikraft specifically.  And now Merlin.
I suggest a nam ;D ;De change to 'The Bag Of Spanners' GB!
I wouldn't write off resin kits as there are some truly stunning kits - Czechmaster, Airkit (sadly defunct), Hitech (ditto).
But yes, that name change is quite applicable.  Widen it to include vacforms and you're onto a winner.  Resin, limited run and vacforms all fit the bill.
Quote from: The Wooksta! on December 09, 2010, 06:49:10 AM
Already done - basically anything that scares you!
I see that there's a separate Scratchbuild GB in the poll, but IMO that would fall within the definition of Fear and Trepidation. I propose to merge the two.
Quote from: Hobbes on December 12, 2010, 04:49:35 AM
Scratchbuild is kept separate since it is most likely going to be much, much longer than normal GB.  Besides, it is far more specialised.
