avatar_FAR148
Invaluable modeling tools. Share yours!
Started by FAR148, December 25, 2010, 05:45:21 PM
Never had any oily residue left by blue tac (and I carried out extensive testing prior to using it when I failed to locate any silly putty) but if left on for too long it can remaining crevices.  The trick is to use old blue tac that has been used for masking before to mask creviced areas as the dried paint that mixes in when you re-ball it after use reduces stickiness sufficiently to prevent the crevice clinging propensities.
Quote from: NARSES2 on June 08, 2014, 08:18:47 AMPlus because we have pound store wars on going in Croydon at the moment everything in the Pound Store (other cheap shops are available  ;D) is 95p  :thumbsup:
Sounds like a diorama waiting to happen
I prefer blue tac to white tac. The white stuff I find sticks too much and can bugger up a paint finish when it's lifited off.
FAR148
Sick and tired of spilling paint, liquid cement, thinner? Here's an easy fix. All you need as a circle template(or a pair of divider) some foam core and a hot glue gun. First, measure the diameter of whatever jar or bottle you want to secure. Next, measure and cut the base. Make sure it has at least 1 inch of space around the diameter of your jar or bottle for the supports. Then measure and cut the supports, making sure they are tall enough to support but not too much so that they get in the way of opening and closing. Place your jar or bottle in the center of the base and hot glue the supports around it every 90 degrees.
Take care,
Steven   :thumbsup:
Quote from: FAR148 on May 26, 2019, 10:55:05 AM
Sure, now he tells us.  ;D
I've done something similar by taking some MDF offcuts I had lying around and perforating them with a drill and/or hole saw (took me a while to find a drill the right size for a Humbrol tinlet, though).
FAR148
Quote from: The Rat on May 26, 2019, 11:50:09 AM
Better late than never!  :thumbsup:
Doug K
Most invaluable tool? These days it's the Internet, whether researching IJN ships or getting inspiration for Whiffs, it's the greatest boon to modelling in a generation.
