avatar_kitnut617
Aircraft Launched Rockets and Unguided Rocket Projectiles
Started by kitnut617, May 05, 2010, 12:08:40 PM
I suggest they pull the nose up as they fire so that the tubes are in alignment with the line of sight.
Quote from: PR19_Kit on February 24, 2013, 06:31:22 AM
Wierd arrangement, isn't it?  :unsure:
Looks like they hinge down from the rear, and presumbly must have the hinges skewed in two planes so they're aligned with the aircraft's centre-line when they're deployed.
I would suggest they swing down into the level Kit, the fairings for these RP's are on the up-turrning part of the underside of the nose going by this photo (and I can see that the aircraft has a nose up attitude in the photo but that doesn't come into it)  You can see here that the demarkation line is much deeper at the rear of the fairing as to the depth at the front of it.
AS.12
Some info from Jane's Weapon Systems 1971
SNEB 68mm rocket variants
TYPE LENGTH mm  WEIGHT kgWARHEAD kg DELTA-V m/sROLE
251P8344.3 1.05 Blast 800  AA
2528264.30.8 Inertn/aAG practice
2539115.051.8 AP  / frag600AG anti-armour
256P9116.25 3.0 Frag450AG
Typical SURA 80mm
LENGTH mmWEIGHT kgWARHEAD kg PROPELLANT kgRANGE mACCURACY
10601133100050% within 10 mils approx.
Bofors 135mm
WEIGHT kgMOTOR DURATION sDELTA-V m/sWARHEAD kgEXPLOSIVE WEIGHT kg
43.5260019 3.7 GP, 5.0 AP Frag
Six of these were fitted into the 104 kg launcher, length 3226 mm diameter 426 mm.  Salvo fired in 0.1 seconds.
