O
Rolls Royce ate my Airbus: The BAC Three-Eleven Airliner - 1/144 Scale
Started by Overkiller, December 27, 2010, 03:50:09 PM
I've found that when you need to fill larger holes, using the correct type of putty is essential. It needs to fill the hole without shrinking, it needs to cure properly (too many putty types can only be applied in thin layers) etc. On my Sentinel project I had a couple of places where I had to keep applying putty again and again, until I used Milliput which ended the cycle.
I've tried Mr. Surfacer; the problem was sanding away the excess around the defect: I found it difficult to confine the sanding to the Mr. Surfacer, so I'd often end up with a flat spot or dip where the Mr. Surfacer had been.
I love the way this is coming together. Gives me inspiration for one of my next builds which is an airliner.
I'm sure I could find something to say about having your flap tracks attached & your tail parts defect free but it's too late now....
Wow...you're almost there ! Best of luck in getting her done. I know I'm rooting for a finish !
Green Dragon
Excellent job Duncan! Looking forward to seeing it finished, always wanted a kit of this since I saw an impression in a mag many years ago.
Paul Harrison
On the bench.
Quote from: Overkiller on March 29, 2011, 11:11:57 AM
Quote from: Mossie on March 28, 2011, 05:02:08 PM
Just be grateful, that unlike Narses, I rarely have trouble with my afterburner....  :wacko:
grist to the mill Dunc....whatever the hell that means  :blink: Just remember revenge is best served cold  :wacko:
thedarkmaster
After breaking twice I bet he goes and paints it black now..........  ;) ;D
