Do-335 Pfeil
Started by sagallacci, December 14, 2008, 04:31:01 PM
My quick take on a dedicated Reno style racer but keeping piston engines (in this case Jumo 222s):
BTW,
I seem to recall reading a few years back that Howard Hughes (or maybe someone else) was interested in getting one of the captured Do-335s for use as a race aircraft.  Can anyone confirm/enlighten?
Thought the twin seater Do 335 could use a different, more stream-lined canopy.
And how about a jet-engined version? Over/under Lightning-style!  :wacko:
The rear should be just about large enough to house two BMW 003s. The nose could be used for heavy armament or an air-intercept radar (FuG 240 "Berlin" or the like).
I like the look of the jet one but it would be a bit of a tail sitter I suspect (the Do335 always looked like it was about to squat IMHO).  Perhaps a Zerstorer with four 30mm in the nose to compensate?  I'd also tend to go with a bottom and two smaller side intakes - the bottom one for the lower engine and the two small side intakes for the top one.  Perhaps with a Fw190 style bubble canopy?
Guys, have a look back on page 1 & 2.
Zero-Sen
That'd be Griffon engined then?
Zero-Sen
It's more likely that they'd retain the annular radiator rather than going to the massive rework
required to mount radiators in the wings. That's
a lot of structural modification and plumbing.
It'd more likely look like a Shackleton rather than
a Griffon Spitfire.
PolluxDeltaSeven
Quote from: jcf on September 08, 2023, 08:20:25 PM:thumbsup:
a Griffon Spitfire.
Maybe, but it's so beautiful like this !!
Quote from: Zero-Sen on September 08, 2023, 03:17:43 PMSpanish Do 335 ?
Wonderfull work, as always ! ;)
(by the way, I sent you a PM, it should be in your inbox  <_< )
-Charlemagne-
-Battlefleet Galactica
