avatar_GTX
F-9 (F9F) Panther and Cougar
Started by GTX, April 14, 2010, 01:09:23 AM
What about a VG Cougar?
Alternatively, what if the RAAF got the Cougar instead of the Avon Sabre?
Having bought a cheap old Revell B-57 and then discovered that it's 1/76th instead of 1/72nd (yes it is enough to make a difference), I can totally empathise Jeff.
My suggestion? Pick the least accurate one and scaleorama it into something totally different... :wacko:
That variable geometry set-up is rather interesting with the fixed portion also including the air intakes.
Maybe this design could be applied to a Sukhoi Fitter as well? Moving the intakes to the fixed portion of the wing could free up the nose for a big radar. F-105 intakes?  :wacko:
ajmadison
Considering the gently rounded profile of the thing, could you chop the edges of the wings and the tail feathers, put a squared off (vector) tail pipe on it, and call it a stealthy Cougar?  If you really want some work, you could rework the landing gear doors, and mod how the canopy attaches to the fuselage.
Quote from: apophenia on April 14, 2010, 12:32:10 PM
How about converting the 'non-standard' Revell Cougar into an AS-1 Kennel-style anti-shipping missile? (Being carrier launched, it could even been recoverable -- although you'd have to be brave to be on that flightdeck  ;D )
I like your thinking! :thumbsup:
Daryl J.
Remember the glove vanes on early F-14's?   How about putting something similar on the Panther/Cougar along the trailing edge of the wing section behind the air intakes?    Why?   I have no idea.  :blink: :blink: :blink:
:cheers: (2008 Knob Creek which is much better than the 2009 post run out bottling)
Daryl J.
A drawing of the same:
