avatar_GTX
M24 Chaffee and anything based on this vehicle.
Started by GTX, August 28, 2009, 01:09:54 PM
T-77:  an M-24 with six .50 MGs as an anti-aircraft tank:
Would have taken about half a second to be nicknamed "porcupine" had it entered service.
Jschmus
I could see those deployed in Vietnam on convoy escort duty, or used for firebase defense.
raafif
There was the LVT(A)5 with Chafee turret instead of the M-8 howitzer one.  The Chaf turret would fit several other vehicles as an upgrade too.
dy031101
#3
While thinking about that ROCA experimental combination of M24 turret and modified M113 hull, I began to have this thought- could the M18 Hellcat's 76mm main gun have evolved into a lightweight version that can be used on the M24 by adopting the weight- and size-saving measures used by the 75mm gun M6?
To-do list here
dy031101
Does the M24 store all its ammos in the hull, or are some of the shells stowed somewhere in the turret?
To-do list here
nighthunter
Sorry for the thread Necromancy, but I felt it would be better to use an old topic than to create a new one.
Anywho, looking at all M24 models, the Uruguayan military still uses up-gunned and new engined M24s. Would love to see some ideas and models being displayed.
I have an idea of whiffing a M24 body with a FV107 Scimitar turret, and adding an M2/3 Bradley TOW Missile launcher, for a light scout tank with anti-armor capabilities.
Martin H
Quote from: nighthunter on September 02, 2012, 08:18:16 AM
sounds like a classic whiff to me.  build it ;D
I always hope for the best.
Unfortunately,
Size (of the stash) matters.
nighthunter
Quote from: Martin H on September 02, 2012, 08:45:17 AM
Thanks Martin, if I could find affordable kits to bash, I will do it, did it in MS Paint already. I want to do it in 1/72 as I don't have the room for anything bigger. Cost is the key, I may have to look in the Trading Post for the parts.
Martin H
Revell do a cheap M-24, its the old Matchbox kit. As for the Scorpion. Airfix.
And both are 1/76th scale :)
Unfortunately,
Hasegawa do the Chaffee in 72nd scale and Ace may do the Scimitar, i know they did the Scorpion but not sure about the Scimitar. Than again can't you use a Bradley Turret on the Chaffee ?
G
nighthunter
Thanks for that heads up Martin, I'll look into both, and even check out the LAV-25 turret. Might use that instead and mount the TOW system on it.
Thorvic, Ace did/does make a Scimitar, just expensive for just using the turret. The Bradley's turret is too tall for what I want, not that it wouldn't fit on the Chaffee.
The V-150 LAV 90mm gun turret would be cool too.
