ZEro Length Launch (ZELL) Systems
Started by apophenia, January 17, 2009, 12:36:18 PM
Love ZELL aplications.  Here was my completed Mirage III ZELL build for the Viva La France Group build.
Just some fuel for ideas - mainly of the trailer in this case:
Hmmm, ZELL would work for a VTOL/STOVL type, get it into the air quickly without using up the usual vast amounts of fuel, you don't have to worry about a strip to land on.
Quote from: Mossie on March 17, 2011, 02:24:55 PM
May I cordially refer the right honorable gentleman to post #4 on page one of this very thread?  ;D
Something that always struck me was that ZELL would actually be very apppropriate for the Harrier....
WHAT!!!!!
Yes it sounds mad, but consider this:
Limitations of ZELL: 1. needs a runway to land back on, 2. zero pilot control until sufficient airspeed reached for aerodynamic control.
Limitations of vectored thrust VSTOL: Max take-off weight limited by engine thrust. Vertical landing isn't generally a problem because the fuel/payload weight is much reduced by then.
A Harrier-style aircraft could ZELL launch at much higher weights than would be possible in VTO, yet still need no runway. It would be safer than a normal aircraft during ZELL because it's reaction control system could be used to control the aircraft & rocket combination from the moment of launch. It's high thrust-to-weight ratio would also considerably assist the rocket allowing the latter to be smaller or the the payload larger. On return, the aircraft could do a vertical landing next to (or even on) the launch vehicle wherever it's sited.
I have something like this in mind if the Gerry Anderson GB ever gets going.....
Note that VTOL does not use vast quantities of fuel: the range limitations of VTOL aircraft are due to their restrictive max take-off weight.
Quote from: GTX on March 17, 2011, 12:57:46 PM
Greg, whats the aircraft meant to be?  I assume it has rocket engines in the fuselage rear?
Quote from: rickshaw on March 17, 2011, 05:17:31 PM
Looks like the Bell D-188a, it had three sets of propulsion engines: podded on the wingtips and mounted in the rear fuselage
Superficially, I'd agree, except that the wingtip engine pods are much more individually defined and there appears to be three engines in the tail and a much broader tail plane with considerable anhedal, compared to the D188 drawings I've seen.
Quote from: Weaver on March 17, 2011, 04:24:19 PM
A case of great minds thinking alike or fools seldom differing??? ;D
Folks,
The aircraft shown (though I was more interested in the 'launcher') was a North American 1950s VATOL (vertical attitude takeoff and landing) concept (don't know the proper NA designation).  Here is another image of the aircraft:
regards,
Launcher is similiar to that of the CONVAIR POGO trailer that they used to transport it around and move it from the horizontal to the veritcal.
http://www.aerofiles.com/convair-xfy1.jpg
Thanks, Greg.  I thought it was different to the D188.  Another of those crazy "nutcracker" designs.   :blink:
I don't think the trailer is as much a ZELL launcher as a means of moving the silly aircraft which doesn't have wheels of its own, around on an airfield.
Quote from: rickshaw on March 18, 2011, 04:23:31 PM
Never said it was - I said "fuel for ideas".
Quote from: GTX on March 18, 2011, 04:53:47 PM
I wasn't suggesting you had.  I was pointing out what I believed it was for.  It could form the basis for a ZELL launcher but I think it would need a bit of beefing up to do it.
saintkatanalegacy
Ivylicious!™
