How big is the canopy/nose of...
Started by rickshaw, January 11, 2011, 06:40:31 AM
I've a few ideas floating around.  I need to know the width of the following models' cockpit canopies/forward fuselages (1/72 of course):
A-6 (any version)
EA-6
Vulcan
Sea Vixen
If someone could measure them, and post the info, it would be most appreciated.
I just happen to have an EA-6 under my desk right now.
Can do the Sea Vixen in a couple of hours - I've got a Revell/Frog one and the Xtrakit one at home.
Quote from: kitnut617 on January 11, 2011, 07:20:38 AM
Doesn't everybody?  ;D ;)
OK, Frog kit has a width of 24.5mm at the point where the wing root/intake fairing ends, which is level with the front of the coal hole hatch, and about halfway along the pilot's pit opening. It narrows down to a shade under 19mm at the point where you would attach the radome part.
Xtrakit Vixen has widths of 24mm and 18mm at the same points, respectively.
With the Airfix Vulcan the forward fuselage is widest immeditately in front of the intakes then tapers off.  You could chop it at any point pretty much.  The panel line immediately in front of the cockpit might be considered the true 'nose', although there are a few panel lines where you could take it off.  I've given you the measurements from those panel lines to the end of the nose thimble in brackets.
Panel line in front of intake (118mm):                            40mm
Panel line in front of cockpit (60mm):                            35mm
Panel line between previous & nose thimble (28mm):      26.5mm
rs,
Do you need the whole nose of the plane for your build or just the cockpit section and then create your own nose for it (yes, I saw your other post).
Quote from: philp on January 11, 2011, 02:45:46 PM
rs,
Good question.  This is a bit of long term planning at the moment.  I am unsure whether I'll use the whole nose or just the cockpit section.  What I do definitely need is the width of the fuselage at the cockpit and the cockpit width.  What I'm looking for is a side-by-side cockpit basically for a new V-bomber to be built sometime this year.  A Vixen style fighter canopy might also be suitable.
To the list I'll add, if I may:
Hawker Hunter trainer...
Going on the guidelines you gave, the Vulcan measurements are:
Fuselage at rear of cockpit:     39mm
Fuselage at front of cockpit:    35mm
Cockpit width:                       19mm
Quote from: rickshaw on January 11, 2011, 04:39:43 PM
In that case I'll give you the fighter-style Canberra measurements, as I happen to have the B(I).8 kit in front of me:
Fuselage:     28mm
Cockpit:       11mm
Thanks, I've already got a Canberra.  I'm loath though, to cut up such a lovely (and comparatively expensive) kit, just for its cockpit area.   Unless someone has a spare 1/72 Canberra nose/cockpit area they don't need?  ;)
Well, I managed to get a pair of PR.9 wings from van883 after his kit bit the dust, he might still have the fuselage?  Someone might also have bits from the old Matchbox kit?
So, anybody able to measure a Sea Venom and a Hunter Trainer (side-by-side seating)?
Widest part of the 1/72 scale Hunter trainer nose by Odds & Ordnance is 22mm
I can do a Sea Venom tonight when I get home. :)
I make the Frog Sea Venom 18.5mm across, level with the wing root. The fuselage is pretty much constant in width, only tapering towards the rear and right before the radome join.
