Main Menu
avatar_Taiidantomcat
Hind-SKL
Started by Taiidantomcat, January 18, 2011, 12:23:01 PM
I have experimented with 4.5mm and 6mm BB's the smaller being steel n the larger being plastic.....not bad a result either.....
Ok so today I sat down and looked at what needed to be done next... puttying? Hmmm. I decided to check the 1/72 apache against the hind to see where I had to make cuts and before I knew I had my razor saw in hand and was going to town! considering how little I had really planned it overall, It came out very well!! I just marked and cut and repeated for a very fun half hour or so:
good to have the Mojo working!
Test fitting it was not easy (the unglued pieces want to slip and slide all over) and finding exactly how to position it was a challenge as well. But I think I finally got it:
I was afraid to sneeze lest the whole thing come undone! Then I got really gutsy and taped the sensor on there:
Overall shockingly easy! And Although not a dead on match to the ATE hind its surprisingly close! Looks like a prehistoric insect (the perfect look!) My original plan was to cut the side sponsons down until it fit perfectly even up front, but I realized I can simply fill that gap up in front of the cockpit (near where the white tape is) and just say "Done!" which will be faster and much easier. I finally did sit down and putty it:
New spares!
Cool CG image:
I had another idea for the utility hind as well, A third engine like the CH-53E  :wacko:
Just a suggestion about the sensor area to get a better fit, perhaps cut the nose area from your Apache off from the cheeks and then fit the parts separately. This will allow you to have a circular mounting for the upper sensor instead of the odd shape in the pictures and the cheeks can be faired in after fitting however you wish to fit them.
It's looking great so far  :thumbsup:
Way, way cool!  :bow: The insect-like appearance is very fitting in this case. The Phalanx ammo drum and the spindly legs will add to that as well.  :thumbsup:
What did you glue the LEGO part with? Does it work with normal modelling glue?
saintkatanalegacy
#35
Quote from: Taiidantomcat on January 30, 2011, 01:31:44 PM
easy huh? :rolleyes:
looks like I have to come up with something more difficult then :wacko:
Ivylicious!™
saintkatanalegacy
hmmm... wonder what has become of this project :unsure:
Ivylicious!™
I have been busy! Might work on it more today
I like the look of this very much! :)
Oh yes......way cool,awesome...!!! Work faster at work n do more modelling..... :thumbsup:   ;)
This is going to be a winner, SURE! :wub: :wub: :wub: :wub: :bow:
pedrospe
that is an amazing version of the mi-24 and this last picture of the helicopter,looks like a cgi design, great work.
regards
Pedro
Stargazer
Quote from: pedrospe on February 12, 2011, 06:26:03 AM
Read again. Last pic IS a CGI image given as a reference of what the model could look like when finished!  :rolleyes:
saintkatanalegacy
Quote from: Stargazer2006 on February 12, 2011, 08:14:18 AM
you sound almost like AG here :rolleyes:
Ivylicious!™
Stargazer
Quote from: saintkatanalegacy on February 12, 2011, 09:26:41 PM
:unsure: :unsure: :unsure:
Who's AG???
