Re: Which kit is better? Now A.W. Meteor...
Started by rickshaw, January 28, 2011, 05:13:31 AM
Ed S
Quote from: rickshaw on January 28, 2011, 08:49:56 PM
I assume the major visible difference between a F-5B and a F-5F was the nose shape?
The engines were more powerful, meaning slightly different exhausts.  The wing LERX were quite different, larger on the F.  Also, IIRC, the F was overall longer than the B.
Ed
Interestingly, I've found this review - http://modelingmadness.com/scotts/mod/us/trumpf5epreview.htm
Claims Trumpeter made an F-5E kit but I can't find any other reference to it anywhere.
Nigel Bunker
F-5B is about the same length as an F-5A/E but an F-5F is longer - it has basically had an extra cockpit fitted befing the normal cockpit, and the fuselage stretched to accomodate it.
I hope this helps - i cobbled it together from the net. In descending order F-5A, F-5B,F-5E, F-5F
Thanks thats a great help!  I presume they are all to the same scale?
Another one of those aircraft where the 2-seater looks miles better than the single seater.....
P1127
#20
Bit more than just the shape - the 'B' put the second canopy behind the pilot position of the original F-5A, the F-5F saw the forward fuselage extended to fit the second seat. The differences between the F-5A and E are considerable as well.
If you want to do a T-38 from an F-5B, the main changes are to the intake shape, the underfuselage (Flat on the T-38, bulged around the u/c bays on the F-5) and the undercarraige and wheels. I have an article on how to do it from FSM years ago.
It's not an effing  jump jet.
Quote from: rickshaw on January 29, 2011, 12:05:27 AM
Oh, the kit is real all right. A friend of mine has got one, but the canopy was a "short shot". The decals are better dumped as well. But the rest isn't too bad.
Now, to the Sukhoi Su11.
Which is better?
Leoman vacuform?
Leoman Resin?
Leoman short-run injection?
Amodel injected?
Are there any other candidates?
I assume that the Leoman ones are all variations on the same theme, with just the media changed.
Daryl J.
Quote from: Daryl J. on February 02, 2011, 09:30:15 PM
Who tooled KP's Su-11?
I believe the Su series were their own. While KP has re-boxed Heller, many of the Central/Eastern European subjects were their own work.
BTW have you hard that American Eagles are going out of business? The closing sale started January 31 and goes to April 9.
I wasn't aware they did one.  It was 1/72, as the others I mention are?  I know I didn't make it clear.
Quote from: rickshaw on January 28, 2011, 05:38:48 PM
Oh, bugger.  Thats the one I've just bought two of, off Evilbay!  Oh, damn, caveat emptor.   I've read a couple of reviews of it and they seem to be OK.  One had an excellent set of pictures and there was no flaw in the canopy.  Perhaps you just got a bad one (fingers crossed)?
Well I got a bad two, but then they were together on the shelf in the shop so maybe they came from the same bad batch?
Best of luck.
Quote from: rickshaw on February 03, 2011, 02:00:15 AM
Don't think they have, they did a Su-9 (same kit as Maquette?) that you could bash but it's probably easier to go with the others.
Quote from: rickshaw on February 02, 2011, 07:41:43 PM
Which is better?
Leoman vacuform?
Leoman Resin?
Amodel injected?
According to the PAK-20 book, the outfits that made the Su-11 were AAA Models, Cramer-Craft, Elliot and Leoman, all in 1/72 scale.  Looking through the KP listing, it doesn't show an Su-11, Su-9 and Su-22's yes ---  AAA Models later became Leoman.  Looking through A-Model listing doesn't show an Su-11, Su-15 and Su-26, yes.  The book has been known to be in error sometimes.
frank2056
Quote from: kitnut617 on February 03, 2011, 06:39:03 AMLooking through A-Model listing doesn't show an Su-11, Su-15 and Su-26, yes.  The book has been known to be in error sometimes.
A-Model Su-11
I don't know how good (or bad) the A-model kit is, but it has to be far better than the Leoman trench digger's special.
