Main Menu
avatar_Gondor
SEAC Meteor F2
Started by Gondor, February 13, 2011, 10:12:43 AM
It's flat with a sort of latticework on top.  Well, that's what I always do as I used a Vic Scheurman article on upgrading the Airfix Meteor some years back and just keep following it.
"Visit Scarfolk today!"
Quote from: The Wooksta! on March 08, 2011, 04:31:49 PM
Am I correct in thinking that was in Scale Aircraft Modelling ?
Forgot to add that more filler has been added to help get the upper wing surface correct and to try and fill in the gaps next to where the engines will hang. Pictures to follow over the weekend as well as a lot of dust production as I sand away at the plastic and filler :thumbsup:
No, I think it was Military In Scale, same issue as the Tamiya He 162, June or July 2006.
Vic Shuerman did write for SAM, an endless and interminably dull series that was spun out far too seriously long enough by half.
Ok, Just to prove that I have not fallen asleep on the build....
The picture shows that I now have the engine nasals fitted to the wings.
A better view showing that there are still gaps big enough to hide the Grand Canyon in that still need to be filled so that's the next task. The fuselage is only in position to show how it looks with the new engines fitted. Still got the Instrument panel to make and fit before I close up the fuselage half's. Weight will be added behind the cockpit and before the fuselage is glued to the wings. Hopefully more progress pictures tomorrow.
Nick the spare from the Matchbox/Xtrakit NF kit? The coaming with gunsight will come in handy too.
Wonderful idea Lee. Think I will use the Joystick as well from the Matchbox kit. I hope to get this beast finished for Perth then I can concentrate of the other builds I have on the go.
Really looking forward to seeing this one Alistair, coming along really well  :thumbsup:
Doc Yo
 Looks like its coming along nicely.
I have slowed down a lot on the build recently. Too much filler applied over the weekend has made the PSR look daunting to me :banghead: I must get around to attacking the PSR to move this build forward of it will end up like so many other models that I have started...... and never finished.
decided to try and get my PYÖRRCTUULI built for Perth as well as the Meteor
Keep the faith Alastair, it'll be worth it! :thumbsup:
I started to think about the final colour scheme for the Meteor and have decided to do a NMF with the dark blue/black? identification stripes, means I can easily paint the thing using Halfords Nissan Silver but I don't know the colour of the ID stripes or an equivalent tin of enamel to use.
I wouldn't.  Given all the PSR, an NMF is the last scheme you'd want as it'll highlight ANY flaw.  You've got to be very confident that you've found every one - and then you'll find more.  Trust me on this!
Besides, Nissan Silver is too grainy for 72nd.  Halfords Gloss Aluminium is closer the mark.
Blue stripes for NMF.  Roundel blue is what you need.
Thanks Lee, I could always brush pain on the finish which would not show flaws as badly. This is my first major cut and bodge with PSR model so I kind of expect there to be some flaws especially as I am working to a schedule.
More work done today,
Decided to apply some primer to see just how bad my PSR was as it felt horrible under my finger tips. It doesn't look half as bad now compared to how it did with a mix op colours of plastic and the putty  all mixed up.
This shows how I finally got the instrument panel to stay put inside the cockpit and with the correct orientation as well!!
More work to do and only four weeks untill my self imposed deadline !!!
