avatar_Tophe
Blohm und Voss P.196T STOL
Started by Tophe, February 16, 2011, 10:08:17 AM
After the joke of my sparebox model, let me start the next "serious" model: Blohm-und-Voss P.196 twin-boomer of Planet Models 1/72:
Well, the P.196 has not been built and this is already what-if, but I NEED a further step in what-ifery. So... as I need a reduced size, there will be no external wings but biplane wings or something. At least. Or I may install a lift enhancer (radial engine/nose of Hellcat I found broken) to give STOL performance...
How about as a WIG aircraft?
Wing
In
Ground effect
GOndor
You are right: such a short span with vertical lift power could direct to the WIG class. Thanks! ;D
Cool! Tandem-wing and/or WiG would be cool. What about mounting the engine on a pylon above the fuselage, like a lot of flying boats had?
Oh, thanks for this new idea... And if tilting/rotating, it could provide STOL ability maybe. I hope I will have skills enough...
For the pod, I will use only the part above: to be streamined, and no need of jet engine below as there will be a radial on pylon...
Well advanced BUT: HELP! (For the very first time in my life I succeeded in preparing) the thermoformed canopy, HOW TO GLUE IT? If I remember correctly, my cyanoacrylate glue would dissolve it... So how proceeding? Thanks.
Tophe,
ACC may not dissolve the canopy, but it will probably frost it.
I'd try white glue, or the French alternative (Glue Blanc?) or the pukka stuff would be Kristal Kleer, otherwise used for making small windows in models. It'll take a while to dry so you'll have to clamp it in place.
Yes. The white glue mentioned by Kit is normally used for glueing wood, but it works okay for keeping a canopy in place. It's not very strong, and it dissolves in water.
Stargazer
Quote from: Hobbes on March 02, 2011, 01:40:24 PM
That's what we call "colle blanche or "colle vinylique". It's great for wood, paper or fabric.
Thanks a lot for your gluing advices, so useful! :cheers: :thumbsup:
Well, the principle of this aircraft is progressing also in my mind: I was both interested by the suggestion to make it a WIG and worried by the use of a so big tube as pylon for the engine; together this brings the answer: the tube will not be only a pylon but an exhaust tube towards a vertical motorjet, providing both STOL and WIG abilities... :blink: ;D
Featuring the motorjet tube (providing lift, that makes unnecessary external wings):
Opposite: hiding the big tube...
