Main Menu
avatar_frank2056
Hispano Aviacion HA-207
Started by frank2056, February 21, 2011, 01:18:11 PM
frank2056
Quote from: dumaniac on March 28, 2011, 11:26:33 AM
well done with a challenging kit - I have never done a full resin kit so hats off to you
It's not that bad of a kit; it is a bit worse than other AV resin kits - poor fit of the cockpit in the fuselage, NO positive attachment for the fuselage to wing joint (just two flat faces) very brittle (in my example) vacuformed canopy and delicate unreinforced resin landing gear.
Quote from: dumaniac on March 28, 2011, 11:26:33 AMa wee bit of super sticky or tacky glue might hold the nose to the base - also if you sand the main tyres a bit flat, it might "want" to sit a bit more forward (depending on how much weight is out back)
I used museum wax under the nose gear and that holds it down. The main gear is slightly flattened, but there's just no overcoming the weight of the tail.
Frank
