Turbo Prop Oceanic Research Plane Idea
Started by Cobra, February 21, 2011, 09:10:00 PM
Cobra
Hey Guys, just had an Idea. What If the B-36,Avro Shackleton,TU-95,Etc. were used as Oceanic Research Planes,Dropping Probes,Etc. for Ocean Research? the Reason i ask is because i thought a Plane like the B-36,Etc.being powered by Turbo Prop Engines would be able to Remain aloft a Lot Longer than a normal jet for that Purpose.  What Say You? Thanks for looking.Dan
Maverick
Dan, I believe the USN had P-3s modified for just that purpose operated by the NRL (Naval Research Laboratory).  They were either RP-3s or NP-3s, I can't recall which, but were specifically modified for oceanographic research.
HTH,
Mav
Quotea Plane like the B-36,Etc.being powered by Turbo Prop Engines
No B-36 was ever powered by turboprops.
Maverick
For that matter, the Shack wasn't flown operationally with Turboprops either.  In truth, high-endurance aircraft (with exceptions of course) are usually turboprop by default (eg: Orion, Tu-95, etc)
Regards.
Mav
#4
Is this the point at which the proposed Shackleton MR5 with the Napier Nomad diesel engines makes a guest appearance?
tigercat
You could do one in a lovely turquoise as part of the National Underwater and Marine Agency (NUMA) from Clive Cusslers books.
MiB
Quote from: Rheged on February 22, 2011, 03:29:08 AM
I think you'll find it was the MR.4 Rheged,
It was offered as an all Nomad engined aircraft, or two Nomads and two Griffons and like this with R-3350 radials.  You'll notice it was to have Vulcan (or Belfast) main u/c gear
Like a 4 engined Mercator! I love it, and easily buildable too.  :thumbsup:
Quote from: kitnut617 on March 19, 2013, 11:58:10 AM
You are  quite correct!  I can only plead either a slip of the finger or age and decrepitude.   Kit is  right, it would be an interesting build.
I've got most of the pieces collected to build one, I wanted to do it with the Nomads but I've not been able to find a photo of the test aircraft which had them mounted on the wings so I can see what the nacelle looked like.  I've seen all the ones of the Lanc with it stuck in the nose though, but I don't think that was the nacelle shape.
It's either that or go with the R-3350 version.
A turbo B-36 would be a fun whiff.  An ocean research version would make a great story.
Quote from: kitnut617 on March 19, 2013, 05:00:43 PM
You're on a winner there then Robert, no-one will be able to say you're wrong so you can go with any shape you like.  ;D
martinbayer
Turboprop B-35 version or better yet B-49!
Martin
I'm building a tanker version of the Shackleton with radial engines from a Constellation. I did try using  four Allision T56 turboprops, but I'm using them on another Connie build.
