avatar_The Rat
Is my mojo finally returning?
Started by The Rat, February 26, 2011, 09:53:14 AM
Two, 2!, blood sacrifices to the modeling gods in under ten minutes! Pierced left my left index finger with a file while thinning an intake lip, then mildly sliced my right thumb while trimming some flash. YEAH BABY!!!
Just in case you're wondering, it's an old Airfix Gnat that will probably be painted as an RAF target drone.
Painfull, this mojo stuff.........  ;)
TR,
are you boasting or complaining? :blink:
Radish
An excellent use for the old Gnat. Have you seen that Airfix are doing a new mould?
Quote from: Radish on February 26, 2011, 11:06:27 AM
Yep, but older ones are good enough for what I inflict on plastic!  ;D
The modeling gods are pleased with your sacrifice... you may keep all your limbs and digits ;D
I can totally understand an Airfix Gnat making you want to stab something - try the Gnat next time though....
Quote from: Weaver on February 26, 2011, 01:42:47 PM
Yes, seems a particularly evil bit o' work, but she should look good in hi-viz yellow and red. Anyone know exactly which paints I should use?
Xtrakit Sea Vixen instructions call out Red Arrows Red (BS537) and Golden Yellow (BS536) for their paint range. Hope that helps.
Quote from: pyro-manic on February 26, 2011, 02:55:27 PM
Ah yes, the old BS Numbers, fully explained here!  ;D
YEEEEEHA! Just found a (crappy) 1/72nd AIM-9 in the spares bin, think I'll have that impacting the Gnat!
I'm glad you found your mojo. I still haven't found mine....
Coming along gradually. Hole drilled for the impacting missile, the toothpick will be painted to represent a flame. Cockpit has been blanked off, don't need bang seats in a drone now, do we?
Painting is just about done, bit of 'touch up' here and there, pull the masking off the canopy. Sure is looking shiny!
