whacky Locomotives etc (real & steam-punk)
Started by raafif, March 06, 2011, 06:28:58 PM
Quote from: ysi_maniac on June 07, 2022, 08:15:35 PM
Railways models enthusiasts are very lucky: they are supplied with wonderful models, already done and funtional. :rolleyes: <_< ...
Quite expensive too. :-\
But they can still be Whiffed, as can all good models.  ;D
Quote from: PR19_Kit on June 08, 2022, 03:16:49 AM
Hear hear!
I am investigating a "Project Cancelled" steam train to build. A Decapod, otherwise known as a Class A55 which had a 0-10-0 layout. If..... and at the moment its a very big if, I manage to get information which allows me to build one it would turn a few heads.
Grosser Junge
What if Big Boy config was applied to german BR42?
Top, BigBoy; center, Grosser Junge; and bottom, BR-42
Like something Herr Hitler would have specified.  ;)
Impressive nonetheless.  :thumbsup:
One vision of Soviet Atomic Train. See track gauge :o :blink:
This different design is marked as Soviet Atomic Train too. Track gauge looks huge, only two floors, ... but those rods connecting wheels looks steam. ???
US Atomic Train ... doable IMO, at least for whiffers. :thumbsup:
Quote from: ysi_maniac on June 17, 2022, 12:53:44 AM
Nuclear reactors produce steam, so it's possible this was a direct-drive design. The other method (reactor->steam turbine->generator->electric motors) is more complex.
Comparing X12 with Big Boy
Perhaps some of you can help me:
1. I assume X12 is an articulated locomotive. In this drawing I see just an articulation between main locomotive and the cooling car.
2. Is it possible for head piece to be supported by three bogies? Should it be another articulation? Where? ahead control area? Between control area and the reactor?
3. What is the steam generator in control area? Is it the generator to heat the train (mentioned in text)?
Thank you in advance.
Quote from: Hobbes on June 17, 2022, 03:43:40 AM
Mechanically a steam turbine-generator system is less complex.
Quote from: ysi_maniac on June 28, 2022, 09:59:07 AM
1. It looks like that, yes. The reactor is so heavy that it supported on two span bolsters, each one of which is supported on two bogies. Then the condenser car is trailing along behind with its rear end supported on a fifth, solo bogie.
2. It's not on three bogies, it's on four, as explained above.
3. Quite possible and very common in the 40s - 60s. Steam heating for the passenger cars was the most common method then, even when diesels came along, many of them had steam heating boilers installed.
Ya know, I'd hate to see one of those derail.
Too true, re-railing a normal loco is difficult enough, let alone an articulated!
Don't ask me how I know this................
All the lead you'd have to wear wouldn't help.
On a similar note, does anyone make British Nuclear Fuels flask train wagons in OO or HO?
;D
