avatar_Tophe
OVA-10 Broncasy
Started by Tophe, March 20, 2011, 08:33:00 AM
Not glued yet, nor putty-sanding-repeat on the wing tips, but the overall shape already appears:
The same after:
- gluing the main wing to fuselage and boom
- putty and sanding all wing truncated tips
- gluing the tailplane
- adding putty on the nose hole
I will have a problem with the lowest wing, probably, but I think I can do it.
The triplane is built. I am just having a hard time with the canopy in 4 parts holding each others... I have glued 2 parts to stand and support the others. This would make more difficult the black painting of the whole canopy as I planned, but maybe I will take that as an opportunity to make it even more different: small eye (what you call single-seater)... ;D
3 of the 4 canopy parts are glued in place. This will work at last. We now "recognize" a Bronco, somehow... :blink:
The 4th part of the canopy is glued, with success. Next week painting and (if not all broken when hold for painting) it will be finished...
Quote from: Tophe on March 27, 2011, 06:43:18 AM
(if not all broken when hold for painting)...
Surprisingly, the model did not fall into pieces when I turned it upside down to paint the underside...
Drying, close to completion...
The asymmetric single-seat single-engined triplane Broncasy is born...
Other angles of this true what-if one (what-if designers were crazy?)...
saintkatanalegacy
Quote from: Tophe on March 30, 2011, 09:05:46 PM
what-if physics was crazy ;D
Ivylicious!™
