Main Menu
avatar_The Wooksta!
LF: Spitfire bits
Started by The Wooksta!, April 02, 2011, 09:56:21 AM
There are some Spitfire bits and conversions that I am keen to get my hands on.  I have a copious spares box but these bits have run dry.
MkI canopy - Hasegawa
Must be the flat prewar one.  The only spare one I have is a bit tatty.
Mk Ia canopy - Airfix
MUST be the from the 1970s tooling. It's the best canopy to replace the awful one in the Hobbyboss kit
Exhausts
Must be from either the Airfix Ia (70s) or Vb.
Aeroclub
Mk XII vacform fuselage conversion.  I have several early Griffon PR conversions in mind and this is the best option given that it's intended for the old Airfix Ia wing.
TIA.
"Visit Scarfolk today!"
thedarkmaster
Is the Airfix one the one that is currently in the starter set with glue and paints ? if so i have a couple you can have mate
I *think* so.  If the codes on the fuselage are AZ-H it is.  A quick look inside the box would confirm.  Raised panel lines = 70s tool.  Still a nice kit and worth every penny.
thedarkmaster
Ok then mate i will send you one, got a few from when we did a make and take day !!
Whole kit?  You're a star!
