O
Up, Up and Away - The VTOL/Helicopter GB Inspiration thread.
Started by Overkiller, April 26, 2011, 01:47:34 PM
Overkiller
A few from me:
Early Mil Mi-24 mock up:
Kaman K-140 Rotodyne analogue:
HS Helicrane proposals:
Mi-26 Flying Crane proposal:
Cierva Autogiro.  Autogiro's are unfashionable, maybe a modern version?
Dragon Warrior UAV
Eagle Eye UAV:
Rotodyne! :thumbsup:
Avpro Exint pod, ideal addition to a helicopter or V/STOL type:
Homer:
Dornier AVS
HS P.1214 X-Wing
Spectrum Cloudbase:
UNIT Valiant
McDD JAST proposal (think it would have been F-36?)
Bristol Jumping Jeep proposal:
Folland Jumping Jeep proposal:
Hawker P.1126
Curtiss Wright Air Car (more an air cushion vehice than VTOL, but just give it a bit more thrust)
Flying Saucer Bus:
Westland WG-33 'flying jeep'
And of course, let's not forget the Moller Skycar: available next year, or the year after that, or the year after that....
(I found a brochure for it circa 1983 while I was looking for something else: it hasn't changed much)
dy031101
#4
The titular jet fighter from "Raiden" arcade series can takeoff vertically via tilting main engines and liftjets.  ;D
A picture showing it can be found here.
I brought this up because I'm a fan of the series.
To-do list here
Gloster projetcs.
Transports.
Fighters.
Meatboxes.  ;D
I know we have been having issues on the site with excessive pictures so I will post a couple links from elsewhere on the site, and you will have to trust that they are well worth the mouse clicks:
http://www.whatifmodelers.com/index.php/topic,30133.0/highlight,helicopter.html
http://www.whatifmodelers.com/index.php/topic,24903.15.html
SNECMA Coleoptre:
Focke Wulf VTOL:
BAE 'Antigravity aircraft'
HS P.1141:
Skycat hybrid airship
Hafner Rotabuggy
Soviet convertiplane (anyone know what this is?)
Avpro Avenger UCAV
Avpro UCAV-1
Avro WS606
Avro Silverbug:
HS.681
Flapper Ornihopter.  This one wasn't capable of VTOL, but there's a lot of scope for Ornithopters
Groen Brothers gyrodyne, early version
Groen Brothers Monsoon
Thiel
Wow, the Avro Silverbug gives a new meaning to mid-air collision.
Yeah, the idea behind the Silverbug was it's use as a high speed rammer.  It would have had a max speed of around mach 3.5 & would have had no offensive armament, just a hardened edge to the saucer.  I've never been comfortable with the idea of ramming aircraft, it's alright the designers & brass saying it's largely invulnerable, let them fly it at mach 3 into several hundred thousand pounds of nuke carrying metal!
:drink: :drink: :drink:
I'm not joining the GB (way to much work piled up) but here's one I was working on as an example.
Project's stalled though (my mind wandered off in another direction)
Thiel
They're 1/72 Harrier fuselages (without the cockpit) attached to a 1/72 Canberra, they're about the same length as the Canberra nacelles.
You can see the build to where's it at on this forum if you do a search for "STOVL Canberra"
