Main Menu
O
Requiem for a Rocket Fighter: - The Saunders Roe P177N Fleet Fighter
Started by Overkiller, April 30, 2011, 02:10:43 PM
Quote from: Weaver on June 26, 2011, 04:07:40 AM
1. HTP reacts violently with water: do you really want a damn great tank of it in an aircraft carrier, no matter how well protected?
I don't think so.......
The ground crews flooded the area with water to counteract any spills when it was used in the Blue Steel and (as T-Stoff) in the Me-163. HTP reacts with other catalysts to produce steam and oxygen, the catalysts can be many things, including something as innocuous as a handkerchief. The Navy used HTP as a fuel in two submarines at one time, the Excalibur and Explorer. OK, they didn't work that well but using it in a submarine would not indicate that it didn't mix with water!
Quote from: PR19_Kit on June 26, 2011, 12:00:22 PM
Sorry, yes, you're quite right: water dilutes it (I was getting confused with something else). Nevertheless, it remains a highly reactive substance which is dangerous when in contact with a wide range of common materials. It's accidental release on a an open rocket launch pad is quite dangerous enough: the possibility of it being released into the closed, complex and densely-packed environment of a carrier represents an appalling risk in my view.
