Bristol Blenheim
Started by tomo pauk, May 05, 2011, 08:16:47 AM
tomo pauk
Blenheim with Merlins 'stead of Mercuries, along with Boulton Paul turret (both to cancel out the increased forward weight, and to provide some serious fire power). RAF's Ju-88 :D
QUESTION: how do I attach pictures?
Pablo1965
some ideas, may be an american engine an one seat.
Uploaded with ImageShack.us
or an landing gear in the nose...
Any Merlin installation in the Blenheim would be along the same line as that adopted by the Beaufighter.  You can't just bolt a Merlin in place of the Mercury as the thrust line would be a lot higher, resulting in a lot of handling problems.  Another is the way the prop rotates - did the Merlin have the same rotation as the Mercury?
In fact, the Merlins might be too powerful for the airframe - the Hercules was considered but rejected for the Blanheim V.  It's one conversion I did have a think about.  A Merlin Beaufort was considered.  I have thought about either a Taurus Blenheim or using the same engines that the Aussies used on the Beaufort on an Aussie Blenheim.
As for the turret - Bristol made their own for the Blenheim and later the Buckingham.  I can't see the Boulton Paul one being used when they were needed for the Skua and the Defiant.
That Blenheim/P38 hybrid is quite frankly awful.  Aerodynamics all to cock with that and the u/c is an engineer's worst nightmare. Unless he's German, in which case he'd say it was too simple.
"Visit Scarfolk today!"
tomo pauk
Quote from: The Wooksta! on May 05, 2011, 09:37:40 AM
Indeed - a Beaufighter before Beaufighter :)
QuoteYou can't just bolt a Merlin in place of the Mercury as the thrust line would be a lot higher, resulting in a lot of handling problems.  Another is the way the prop rotates - did the Merlin have the same rotation as the Mercury?
This is the general idea to upgrade Blenheim into something more powerfull, feasible before WW2.
QuoteIn fact, the Merlins might be too powerful for the airframe - the Hercules was considered but rejected for the Blanheim V.
The Merlins I have in mind were the early ones, with 1030 HP and slightly more. Hercules was perhaps 1500 HP capable, in the time of Blenheim V?
QuoteIt's one conversion I did have a think about.  A Merlin Beaufort was considered.  I have thought about either a Taurus Blenheim or using the same engines that the Aussies used on the Beaufort on an Aussie Blenheim.
Twin Wasp Blenheim seems like a cool idea :)
QuoteAs for the turret - Bristol made their own for the Blenheim and later the Buckingham.  I can't see the Boulton Paul one being used when they were needed for the Skua and the Defiant.
(typo - Roc, not Skua :) )
Any good turret is fine; I do like BP one though. Plus, perhaps using it at a (on a paper, at least) more usable plane would've been better?
I've been thinking of some RAAF or RNZAF Blenheims - both Mk1s and follow ons in SEA service in the early part of the war...maybe as a stop gap pending delivery of the first Beauforts.
raafif
#5
did this --
That's pretty much was I was thinking of, although in RAF rather than RAAF markings.  There's a Highplanes Beaufort in the stash and a spare set of Lancaster outer nacelles to have a bash at it.  Highplanes also did a Merlin Beaufighter so that'd give me a template for the u/c cutouts.
Although the Special Hobby kit may be an easier starting point, especially as the nacelles are separate.
raafif
I just stuck the HiPlanes Beaufighter II wings straight onto the Beaufort.
Quote from: raafif on May 11, 2011, 06:05:39 PM
Which should work.  Afterall, the Beaufighter was essentially made using Beaufort wings and a new fuselage.
Does any know of a handy source of information regarding Blenheim serial numbers?  Ideally something available online downloadable if possible, ideally searchable?
Alternatively something in print?
Or does one of you have info that can be discussed by PM?
Asking to aid/inform research into a RW modelling idea.
Thanks in advance.
The Graham Warner tome, The Bristol Blenheim - A Complete History, is probably the best I can think of. And I distrust any Richard Franks Datafiles as he's short on accuracy and high on pretty pictures. His Mosquito books are riddled with errors.
Said book has the serials listed, including Finland and Canada. Mention of Yugoslav production but no serial numbers.
I have the Putnam Bristol Aircraft since 1910 which contains appendices of Bristol aircraft production by type, constructor number and service serials - RAF and others, or civil registration. This includes production under license by other contractors.
Which Blenheim info are you after? Go ahead and drop me a PM.
Cheers, Jon
Try here, https://www.ukserials.com/
You can take a wild guess and then fine tune the search using 'Ctrl-F'.
Quote from: PR19_Kit on December 22, 2023, 12:47:09 PMTry here, https://www.ukserials.com/
Ah yes, forget about that site.  Thanks Kit.
