Sword Models
Started by Maverick, May 26, 2011, 11:01:34 PM
Quote from: Mossie on February 17, 2024, 11:45:17 AM'Fraid not, it's moulded on. It doesn't look too hard to remove it and fill the gap though:
https://www.super-hobby.com/products/Fairey-Gannet-AEW.3-19452932.html
Hmm, if I could remove it without damaging it too much, it could be utilised elsewhere I suppose. :thumbsup:
If you took a fine razor saw to it, it should come off nicely with some care.  As a bonus, when they fitted the radome to the Shackleton they used a collar to make it fit.  Something similar could hide any rough edges.
Quote from: Mossie on February 17, 2024, 12:26:22 PMIf you took a fine razor saw to it, it should come off nicely with some care.  As a bonus, when they fitted the radome to the Shackleton they used a collar to make it fit.  Something similar could hide any rough edges.
Sounds like a plan to me Mossie. :thumbsup:
And the same radomes started off on Skyraiders!  :o
Quote from: chrisonord on February 17, 2024, 11:35:07 AMI need to look inside the 1/72nd scale one's box to see if the radome is separate or not, as the airframe sans radome, screams C.O.I.N/ Close air support with rockets and bombs under the wings.
I'd long thought of a normal Gannet used for that role.  Gave up on it as the Gannet is something that doesn't work for me.
"Visit Scarfolk today!"
