avatar_Daryl J.
De Havilland Mosquito
Started by Daryl J., January 07, 2004, 09:23:39 AM
raafif
ooH !! Greg,
             I must add those long wings to my TR.33 conversion ! :thumbsup:
Won't work.  The weight penalty of the wood needed to make a spar strong enough goes against it.   What isn't so widely known about the Mosquito is the number lost due to structural failure of the wing.
I'm always amazed by some people's abilities to look directly through a rough profile sketch, able to accurately visualise the inner workings of said piece of hardware from an engineering point of view and then knowing why it won't work!
Mad skillz!
I have a Mossie whif (Navalized, Highball-equipped, 5-bladed props on Griffons, etc.) in the works (in my mind, + materials gathering). I am SERIOUSLY thinking of discarding the iconic windscreen and using twin bubbles for the canopy, like the American B-42/43 bomber (seen below). Why, you ask? Just because it would look VERY different!!
Wooksta---is your "Dagger" Mossie done?? Pics?
No.  Got abandoned last year when I took my time out.  Plus I need certain resin conversion bits (Paragon's original Mosquito prototype that fits the Airfix kit - which I DID have!) for the nacelles that are proving difficult to find.
Any possibility of using the Rapier nacelles from the Fairey Seafox (Matchbox kit?) instead?
Quote from: GTX on July 16, 2011, 02:11:25 PM
After reading of the flight trials between the Westland Welkin and the dH Mosqito and then taking a certain gentleman's statement that "Any aircraft can be improved by fitting longer wings", I quickly developed the following High Altitude creation:
I think if I was to do that Greg, I would run the trailing edge all the way from the fuselage point to your new wingtip position.  While researching my DH.101 project, I found that the wing of the DH.98 (Mosquito), DH.101, DH.102 were built all in one piece and I don't see why this couldn't too.  The DH.101 and DH.102 were designed at the same time as the DH.103 (Hornet) and that aircraft's wingspar was a wood/metal composite, so the idea could go along the same route.
Quote from: sequoiaranger on July 17, 2011, 09:23:14 AM
I've got the engines and a mould, it's the back end for the short early nacelles that I need.  I decided on the Airfix kit as A: I've LOADS of them and B: the plastic is thick and thus able to withstand major sanding, which I'll have to do to take out the wing root radiators.  The Paragon conversion that I want hasn't been available for about 11 years and the one he had out recently (before he packed in again) was intended for the Tamiya kit and thus won't fit.  TBH, I think the whole thing will be a mess.
Quote from: The Wooksta! on July 17, 2011, 07:47:08 AM
Tut, tut......
This is Whiffworld, remember?  ;D :lol:
They probably used the ultra-strong type of spruce that's only found in the far North of Sweden and probably lengths were flown to the UK using the BOAC Mosquitos.  ;)
That's not so much down to the Mossie as DH as a manufacturer.  IIRC there was hardly a single DH built type that didn't suffer catastrophic structural failure at some time in it's history.
raafif
AFAIK the glues were the problem with the Mossie structure.  One ex-Qantas engineer told me he watched one of the last Mossies taking off in the '50s ... aircraft starts off, gains speed ... tail lifts .... one engine seperates & powers several feet ahead of the rest of the airframe  ;D
Quote from: raafif on July 17, 2011, 05:39:25 PM
.......one engine seperates & powers several feet ahead of the rest of the airframe  ;D
Now there's an idea for a Whiff....
A single Merlin powered Mossie, single seater perhaps, but with the engine mounted assymetrically. Tophe would LOVE it!  ;D
Quote from: PR19_Kit on July 17, 2011, 11:51:02 AM
Tut, tut......
I now have a slightly surreal image of an Indian Air Force Mossie with  a TEAK mainspar
>A single Merlin powered Mossie, single seater perhaps, but with the engine mounted assymetrically. Tophe would LOVE it!<
Yes, make a BV-141-esque "Mosquito", maybe a single, souped-up Napier Sabre engine (or Crecy?) to power it to keep the HP somewhat near the twin-Merlin. Herewith a crude example:
What about one with an embedded engine arrangement:
