avatar_Daryl J.
De Havilland Mosquito
Started by Daryl J., January 07, 2004, 09:23:39 AM
famvburg
       Aerodynamically or otherwise?
Quote from: Caveman on March 12, 2012, 09:41:52 AM
Not always true. Some have both engines as critical!
Quote from: famvburg on March 12, 2012, 09:18:59 AM
   Trust me, unless you have counter rotating props, you have torque & it has to be corrected with rudder. Ask a multi-engined rated pilot rather than modelers. Without reading the article, critical engine has to do with prop rotation direction & which side of the a/c it's on. An a/c with counter rotating engines has no critical engine, but that's different from having torque.
I think I already said that........
Daryl J.
How long could a Mosquito handle Hanoi before rotting?
Look at the Mosquitos in the far east post war.  Not long!
famvburg
     I guess you did, kind of.
Quote from: PR19_Kit on March 12, 2012, 10:18:13 AM
     Trust me,
I'll take you at your word, but I'm still looking for an explanation of how this works, since it goes against all of my physics knowledge. I'm probably overlooking something, but what?
famvburg
     maybe this will help?
http://en.wikipedia.org/wiki/P-factor
Quote from: Hobbes on March 12, 2012, 01:41:21 PM
     Trust me,
Caveman
secretprojects forum migrant
You're thinking of each engine as a separate structure and not connected to the fuselage or its opposite number. The torque effect of each engine acts on the WHOLE structure and not just itself and the fuselage.
KJ_Lesnick
QuoteA high fuel fraction means less weapons load. Not a problem for a gunfighter like the Zero, but doesn't bode well for a bomber.
What are you talking about?  Most of the bombers had higher fuel fractions than the fighters did including the Mosquito.
perttime
QuoteTotally agreed, and the Corsair, Bearcat, Thunderbolt and B-17 were handicapped by their radials...  ;D
Well, the B-17 and B-24 had less range than the Avro Lancaster did technically
QuoteThe Hornet and Twin Mustang had handed props and engines but very few other twins of the WWII period did.
The P-38 did...
Caveman
QuoteNot always true. Some have both engines as critical!
The P-38..
Daryl J.
QuoteHow long could a Mosquito handle Hanoi before rotting?
Dunno, but I don't know if it really matters as I was thinking of a fictitious design with a radial engine and metal-construction.  I don't know if there'd innately be any weight problems if it was designed right.
Daryl J.
QuoteLook at the Mosquitos in the far east post war.  Not long!
Got it.  Thanks again.  :thumbsup:
Quote from: KJ_Lesnick on March 12, 2012, 06:35:46 PM
The P-38 did...
The operative words in my posting were 'VERY FEW'..........
You were talking about taking a Mosquito and increasing its fuel fraction. If you do that inside the existing airframe, a decreased weapons load is inevitable.
Quote from: famvburg on March 12, 2012, 02:32:33 PM
P-factor is a separate phenomenon (asymmetric forces acting on the control surfaces) that will cause a similar effect (roll depending on the power setting).
KJ_Lesnick
QuoteYou were talking about taking a Mosquito and increasing its fuel fraction. If you do that inside the existing airframe, a decreased weapons load is inevitable.
This design isn't necessarily going to be an exact copy of a Mosquito with a radial and a higher fuel fraction.  I'm talking about a different design that is designed around the same concept fictitiously in the same era.
BTW: When were the first laminar flow foils like those used on the P-51 first researched?
