avatar_albeback
It's a Vulcan Jim but, not as we know it!!
Started by albeback, June 01, 2011, 05:30:42 AM
Nah, it would use standoff weapons instead of freefall nukes.
Steel Penguin
 :thumbsup: looking lovely and the overving concorde limpuses  seems to be aa coman thought out here in wif land
albeback
Quote from: Steel Penguin on June 02, 2011, 12:42:02 PM
That would be an interesting development! ;D. There might be practical problems with engine accessibility but, where there's a Whif, there's a way!! ;D
lenny100
#34
stealth Vulcan my idea of one anyway
up engined also with 4 tsr2 engines afterburners removed and rotary bombbay racks!
IanH
Devilfish
Quote from: albeback on June 02, 2011, 05:17:15 AM
Very neat. The Prowler cockpit looks good on the Vulcan.  My own concept would also have a crew of 4 - with the rear crew below & behind in the original "coal hole". Both with ejection seats  (at last!) exiting through a frangible panel on the roof.
Thankyou.  I decided to raise them up as the nuclear capability would have been negligible, as the Royal Navy had our nuclear deterant at the time.  However, the bombbay would hold a rotary dispenser which could carry Tomahawk or similar. (ran out of time to build it tho).  80's and early 90's tech I think would have called for an aircraft this size and with this range to need a 4 man crew.....3 at minimum, as the pilot would need back up on those long haul flights.
albeback
#37
Quote from: Devilfish on June 02, 2011, 11:44:53 PM
I was going to build a bomb bay as well but, being lazy, it never got started!! ;D I've sort of concocted a background story for this one. The redesigned bomb bay would be of modular design - capable of being conformed to suit the mission. E g - 3 x 7 round clips each holding stores of up to 1000lb each ( H E , CLUSTER BOMBS), 2 x 4 round clips each holding 4 x JDAM, LGB or other guided munitions or, a combination of additional fuel tank & whatever munitions the mission required.
Once its finished, my Vulcan will have 4 external hardpoints - 1 either side of the bomb bay & 1 under each wing. These would be rated at (fuselage) 5450 kg each (12000lb) and, (wing) 4545 kg each (10,000 lb) Total disposable load  (including internal) - 20,000 kg. Fanciful? Well, not really because AVRO had designed (but never built) external bomb carriers each holding 12 x 1000lb HE bombs. One to be carried under each wing in addition to internal stores. This would double Vulcan's bomb load.  Doubtless such a massive load would entail taking off with reduced fuel but, as Vulcan was I F R capable, that would not matter.
When completed, my model will have 4 x large external stores. Haven't decided which but, as they will actually be 1/48 items "scaled down" to 1/72, they will be suitably impressive ( I hope!) ;D
In any case, ANYTHING is possible in Whifworld!! ;D
Quote from: albeback on June 03, 2011, 01:06:29 AM
I've seen diagrams of the carriers Handley Page designed for the Victor like that (appear in a book I have), but not anything for the Vulcan.  Got any pics and such ?
Great work both of you! :thumbsup:
albeback
Quote from: kitnut617 on June 03, 2011, 05:37:55 AM
In the book V Force (I think?)  by Andrew Brookes there is a chapter which incluses diagrams of several proposals for an upgraded Vulcan. Fitted with the so called "phase 6) wing, this would have  a crew of 6 ( all with ejection seats!) in an extended forward fuselage. Up to 4 Skybolt missiles could be carried. An alternative proposal was to carry up to 3 Gnat single seat fighters . Another was for external streamlined bomb pods ( one on each wing) accomodating up to 12 x 1000lb bombs each.
albeback
albeback
Quote from: Pablo1965 on June 04, 2011, 02:23:17 PM
This is going well :thumbsup:
Thanks Pablo :cheers:
Since I took that photo, I managed to break one of the wingtips off :banghead:
At that point I decided I needed to seek consolation from my favourite Belgian blonde - Ms Stella Artois  ;D
Quote from: albeback on June 04, 2011, 02:51:24 PM
Stella ...Stella.  ;D
