B-70 Valkyrie
Started by Devilfish, June 09, 2011, 11:32:02 PM
I've got the Warbird Tech book on the Valkyrie, it has various pics of the intakes.  There's one that has a couple of guys sat down in one of them, they could easily stand up.  It describes them as being around 7ft in sqaure section by about 80ft long.  The plenum chamber is described as the size of a 'small bedroom', I guess this isfrom the American point of view because it's the size of the largest bedroom in my house!
Quote from: IanH on June 10, 2011, 08:39:55 AM
They aren't painted - the tyres are impregnated with Aluminium...
Quite possibly, but I wasn't about to dig a small hole in them to find out!
As far as modelling is concerned they'd have to be painted......
I have the AMT one in the stash too, mine is going to get its fuselage stretched and where the wing hinges are put either a pair of big scram jets or for trans atmospheric trips a pair of rocket engines. Mine will be a hyper sonic transport aircraft for S.H.A.D.O, and may even carry a smaller shuttle type craft piggy back.
I will be watching this build with interest for sure, just so I know how many angle grinder disks to buy  :wacko:
Cheers
Chris.
IanH
Quote from: PR19_Kit on June 10, 2011, 12:36:03 PM
No Doubt...
anthonyp
Looking good!  The one I got off eBay was partially built, so I didn't get to enjoy some of the fit problems (as the previous owner actually did a nice job).  I was going to turn mine into a flying spacecraft first stage.
Looking forward to seeing yours completed!   :thumbsup: :thumbsup:
I exist to pi$$ others off!!!
Forgot to say, good luck with the build!  I've often thought of picking up this beast but baulked at the work required.  Anyone who takes this on has gone some b@lls!
IanH
Quote from: Mossie on June 11, 2011, 02:46:40 AM
I've always wanted a Valkyrie, and It's the easiest available ATM - it definately needs Testicular Fortitude! :banghead:
I'm thrilled to see you tackling a B-70, Devilfish! I gave one to a member here for Secret Santa one year and he disappeared from What-If not long after starting it. I wonder if there's a connection?
I like the black scheme and low-viz markings you've got in mind. It'd be neat to see one of these in Vietnam camo ready for a bomb run...or to see one converted into an airliner (TWA, Braniff?).
You've got me eagerly awaiting your next update!
I've read quite a few comments here and other places at what a pig it is to build, I don't understand why though.  My build didn't seem to present any more problems than the C-135 line that AMT has, or the Northrop B.2, or the Concorde I'm building.
Why does everyone have a problem ?  Admittedly it's not a 'Shake & Bake' kit but there nothing there that can't be worked out.
IanH
Quote from: Brian da Basher on June 11, 2011, 07:49:57 AM
Funny - the SEA Cam was what Iws thinking about...
Devilfish
Quote from: albeback on June 10, 2011, 08:34:52 AM
http://www.edwardsflighttest.com/b70.html
Ahhh but, this is Whifworld & realism goes out the window!! ;D
Check out some of the schemes at the link above ( hope it works!!)  I rather fancy the SEA Camouflage example. And, how about the one in the Thunderbirds livery! :o As for the dihderal mentioned elsewhere, I was aware of that but, as far as I'm concerned it's more trouble than it's worth. This kit is difficult enough to build without adding to it.  I can live without it . It's not that noticeable anyway & certainly,nobody that sees my model will be any the wiser.
True, it is a Whif, but I like to keep an air of realism in mine....most of the time, so I tend to stick to what would actually be.  Hence when I did a Vulcan B3, I painted it Hemp, as that's the colour all large RAF aircraft were going at the time.
albeback
Quote from: kitnut617 on June 11, 2011, 09:06:30 AM
Inclined to agree with you. I enjoyed building mine. It was a bit of a challenge but, nothing a bit of time & effort can't cure.
albeback
Quote from: Devilfish on June 13, 2011, 12:55:49 AM
A very fair comment :thumbsup:. Me? I just like to let my imagination get the better of me sometimes. ;D. That was a lovely job you did on the Vulcan by the way. The Prowler cockpit looks good on it!
Devilfish
Quote from: albeback on June 15, 2011, 09:48:26 AM
Thanks.  The idea of using the Prowler cockpit actually came from my best mate, and I was lucky enough to pick up an old Matchbox one at the Peterborough show for a couple of quid....
And compared to the Vulcan, the B-70 is a breeze....
Pablo1965
I like the way you work and give form to the pieces. Brilliant. :thumbsup: :cheers: :bow: :bow:
