Quad Tilt Rotor
Started by Green Dragon, June 28, 2011, 08:20:36 AM
Green Dragon
Been measuring up stuff and will be using the Heller Transall and a couple 1/72nd V-22's if I can find where the hell I've stashed them!
Picked the Transall because I like the sponson shape more than the C-130's.
Planning to cut out the wing box area and shift it to the rear and use extended V-22 wings at the front.
If it all goes wrong I'll probably just do a Rotodyne or something!
Paul Harrison
On the bench.
Cliffy B
Sounds neat!
If you're familiar with the Hellboy movies remember they come from graphic novels.  There is an offshoot series called B.P.R.D. (the agency Hellboy works for) that has some very interesting technology drawn in it.  In one issue there are several VSTOL heavy lift aircraft, one of which is a quad tilt rotor C-130 and a larger tilt rotor with a huge B-29 style greenhouse nose.  I can get some scans of said cells if you'd like them for inspiration.
Good luck with the build  :thumbsup:
-Mike
-Tom Clancy
-Anonymous
-Anonymous
Good to see you cracking on with this one! :thumbsup:
Great minds think a like, I was thinking of a C-130 based quad myself!!
Green Dragon
Hi all, found a Hobbycrap V-22 (still no sign of my 1/72nd Italeri's lost in the bowels ofthe stash!) but I'm going to change scales for the engines/rotors to 1/48th because the hobbycrap ones looked really too tiny to lift a Transall. The designs for the Bell/Boeing QTR state a rotor span of 55 feet and if my maths are right the 48th rotors work out at about 60 feet scalorama'ed down to 72nd and they look okay in the rough tape up I did (engines may be a bit big though!)
Stargazer, I hope it turns out OK, think I'll be needing a lot of luck and shed load of putty!
Mike, I'd like to see the pics of the Hellboy quads, any chance of posting them in the Up, up and away inspiration thread?
Mossie, I had no choice after getting those Transall parts from you, just needed the group build to give me a kick in the butt to get going! Oh and thanks for cutting out the engines, saved me a hell of a lot of hacking!
McColm, I bought all the C-130 transport kits for use on this build, they were going to be the major part of the fuselage with just the cockpit from the Transall grafted on. I think all the cuts would have been easier but I really liked the Transall's sponsons and it's almost the same size as a Herc anyway. Also the Heller Transall is Very sturdy with thicker plastic and fewer door cut outs than any of the Hercs so it shouldn't flex too much during construction. First pics later hopefully.
Paul Harrison
On the bench.
Green Dragon
Some pics wot I done.
Box shots.
The first cut is the deepest (isn't that a song?).
Hit it with a spray bomb from Halfords on both interior and exterior and did a rough tape up, used the civil boxings interior parts as the military bits were a bit warped. Rear rotors are placed where I will be cutting the wingtips off and mounting the engines. 1/72nd rotors and engine are there to show how tiny they are, reckon the only way the the small ones might work is if you contra-prop them. The 1/48th V-22 wing will be extended so the rotors clear the fuselage.
Paul Harrison
On the bench.
arkon
Looks good, I  thought of using my Airfix C-130K, the wings would come from two Hawkeyes, rotors and tail section from a 1/48 V-22. A raid of the spares box could come up with the second set of rotors.
Green Dragon
Don't like Italeri's multi-part rotor blades! Did several rounds of PSR and I can still see where the parts meet, finally gave up and blatted them with Halfords Matt Black spray. Extended the V-22 wings successfully, just got to rub down some Greenstuff in a couple of places and they're done.
Cut down the Transall wings and filled the holes where the old engines used to be with scrap sprue, plasticard and a skim of Greenstuff. Mounted V-22 engine pivots to the Transall wing tips, not sure if I'll try blending them in or leave it with a slight step.
Unfortunately the rear engines are almost in line with the forward ones and may suffer from hot gas ingestion but I might be able to raise the rear wing enough to be clear (may have to make a large hump out of Milliput!).
Hoprfully some pics tomorrow, not sure of colour scheme yet but toying with an Antarctic supply QTR with some dayglow orange or red panels or a civil operated one , really don't want to go overall grey! Thinking of RAF grey/green wraparound or a desert camo (French in Africa?) too.
Paul Harrison
On the bench.
Thanks for the advice.
MiB
Wow, quad...at last!!!
In the movie Transformer 3: Dark Of The Moon the NEST troops used a quad-Osprey. That's interesting...
Green Dragon
Some progress piccies.
Plasticard tabs used to strengthen V-22 extensions.
New wing but not glued yet.
Filling the fuselage gap with Plasticard.
Fuselage setting with wings placed roughly where I'm planning but it's very tail heavy.
Paul Harrison
On the bench.
jsport
Most excellent, super stuff.
