avatar_ysi_maniac
AX-1 and AX-2: Spanish paper projects during 80s
Started by ysi_maniac, June 28, 2011, 11:30:17 AM
This is all the information I have:
AX-1
AX-2
BTW: these projects were mentioned in this thread before:
http://www.whatifmodelers.com/index.php/topic,26474.0.html
I will use this old drawing for reference for AX-2
Mr.Creak
What if... I had a brain?
Interesting stuff.
Can't you use a Gripen kit for the AX-2?
Difficult:
- Air intakes are completely different and in different position
- Nose section in Gripen is not a circle but a rounded rectangle
In addition:
- Look at main wing leading edge root and canard trailing edge root; there is a gap between them. This, IMO, means that sweep angle of main wing is less than 45 degrees. So I am considering the wings of a F-16.
BTW, when I said to use that old drawing 'for reference', I meant 'to see relative positions' and to copy tail fin.
More pics soon :thumbsup:
Quote from: Mr.Creak on June 28, 2011, 11:48:53 AM
http://forum.keypublishing.com/showthread.php?p=764673
http://www.whatifmodelers.com/index.php?topic=26474.0
There doesn't seem to much at all about it. Even my copy of Jane's just says "This project has been cancelled".
In that first link, a non-afterburner EJ-200 is mentioned. How would the nozzle look like?
- without feathers?
- a cut cone? a cylinder?
- 2 concentric cylinders?
Your opinion, please.
Regards.
Mr.Creak
Quote from: ysi_maniac on June 29, 2011, 06:54:33 PMIn that first link, a non-afterburner EJ-200 is mentioned. How would the nozzle look like?
- without feathers?
Good question!  ;D
Are these any help?
http://www.iad-design.de/postprod/ej/photos/img/1h.jpg
(from http://www.eurojet.de/en/index.php?page=image_gallery.html)
This one might give some clue:
(click on "Technical Features" for a good view of how much is afterburner).
And http://www.rolls-royce.com/Images/EJ200_tcm92-6698.pdf might help, as, possibly will
http://typhoon.starstreak.net/Eurofighter/engines.html
I'm looking forward to seeing more, Carlos! Your work never ceases to amaze me!
:thumbsup: :thumbsup:
Thanks for your nice words!
Some updates
Front and aft parts of AX-1 fuselage are not glued yet
AX-2 fuselage is done with an old MiG-21. It was shortened and in the same operation cockpit was moved forward, cutting by the yellow line. Aferwards, air intakes were added.
Nice work so far! :thumbsup:
What kits are you using?
Looking at what you did to the Fishbed fuselage, I seriously think you should build a variant of a Fishbed with intakes like that as an operational Soviet machine. :thumbsup: Big radar in the nose and some huge, early radar-guided AAMs.
Quote from: ChernayaAkula on July 01, 2011, 10:02:52 AM
Thanks!
AX-1
1/144 Arii Vigilante
1/100 Tamiya Phantom
AX-2
1/72 Unidentified manufacturer (same old mould than Academy or Hasegawa) MiG-21F
1/100 Tamiya Intruder (air intakes)
Final result will be 1/72, I think ;D
Great idea for a next project
