avatar_Radish
Harrier and Sea Harrier
Started by Radish, March 12, 2003, 10:55:41 AM
You're driving me nuts! I want to build all of those!
VTOL Alphajet. 6 exhausts :-\  :-\  :-\
So now that we're due for the re-issue of the Airfix P.1127, what what-if ideas do you have for it?
Quote from: Weaver on March 11, 2024, 02:10:22 PMSo now that we're due for the re-issue of the Airfix P.1127, what what-if ideas do you have for it?
Turn it into something Bristol 217-ish.You cannot view this attachment.
Finish it as a Harrier, bearing in mind the Harrier was in the so-called 'real world' developed from the Kestrel.
Quote from: kitbasher on March 11, 2024, 05:00:08 PMFinish it as a Harrier, bearing in mind the Harrier was in the so-called 'real world' developed from the Kestrel.
And that the Kestrel and the Harrier were still model number P.1127.
Quote from: jcf on March 11, 2024, 03:41:14 PMTurn it into something Bristol 217-ish.You cannot view this attachment.
Needs longer wings.......................  ;D
Quote from: PR19_Kit on March 12, 2024, 04:40:50 AM
Even I recognize that necessity, Kit.  What the hell were they smoking when they decided to have wings the same size as the horizontal stabs?
Quote from: scooter on March 12, 2024, 06:02:50 AM
Well, initially it was a design for a Special Forces 2-man mini-sub that they scaled up & tweaked a bit. ;)
Quote from: scooter on March 12, 2024, 06:02:50 AMEven I recognize that necessity, Kit.  What the hell were they smoking when they decided to have wings the same size as the horizontal stabs?
Exactly!
Maybe they figured that the Pegasus would be in lift mode almost the entire time? In which  case they forgot the IFR probe, or probeS even!
Quote from: PR19_Kit on March 12, 2024, 06:13:50 AM
Exactly!
Or provisions for external fuel.
For reference, the P.1127 version represented by the model is one with a 9-inch shorter fuselage than a Kestrel, the delta wing, and thin-lipped intakes with big splitters and no auxiliary blow-in doors. The Kestrel had the intakes with inflatable rubber lips.
Quote from: Weaver on March 12, 2024, 09:01:23 AMThe Kestrel had the intakes with inflatable rubber lips.
My brain had trouble sorting that out because it went wa-ay off in the wrong direction! :-X
Quote from: Old Wombat on March 13, 2024, 01:54:09 AM
Had me thinking of Mick Jagger.
Or Steve Tyler.
