Busch Model Railroad Hangar Q
Started by Cobra, August 24, 2011, 11:24:45 PM
Cobra
Hey Guys, i was at my Local Hobby Shop and saw a Busch Hangar Model,HO scale there. just wondering about building it because it saw in the text that it has Wooden Struts,should i use something other than Regular Model Glue for Construction? could use some advice. thanks for looking. Dan
White glue, if you want extra strength you can get carpenter's glue, basically the same stuff but with a bit more oomph. Regular polystyrene cement won't do the job because it works by actually melting the plastic and welding it together. There are some CA glues that are formulated to work on porous materials like wood and leather, but I've never tried them so you're on your own there. Good luck!
Epoxy glues should give a good, strong & (generally) waterproof result..... Basically like joining things with resin.
