avatar_kitnut617
McDonnell Douglas Alternative Harrier Replacement.
Started by kitnut617, September 02, 2011, 03:28:12 PM
Well, I've got some deep thinking to do now, my initial plan is going to need a bit of refinement as it's not going quite to plan   :banghead:
Does anyone know if there's a 1/65 or 1/75 F-15 produced, the 1/100 scale ones might be a tad small ---  :banghead: :banghead: :banghead:
SinUnNombre
1/72 is a popular scale, so you may be able to find what you need there.
Jon
Quote from: SinUnNombre on September 19, 2011, 01:16:15 PM
Jon
Um! I'm building in 1/72 scale Jon ---  :lol:
EDIT:
Just had a look in the PAK-20 book, a company called 'Big One' produced a 1/87th one --- now where can I get one of those ---
SinUnNombre
Quote from: kitnut617 on September 19, 2011, 01:19:47 PM
Jon
EDIT:
Oh. Putting that on my list of new things learned today.
Jon
I think for the front end I need to start with the fan front, this will determine where everything else will go.
So first thing was to work out a new intake duct for the bigger fan front so I made a small square-to-round (technically it's an offset rectangle to round  ;D )
Then glueing the halves together you can see how it's supposed to go, the last pic shows how the inlets will be orientated, there will be a center streamlined bit going in between them eventually.
Unfortunately, the fan blades are getting a bit wacked around and breaking off   :banghead: :banghead:
Quote from: kitnut617 on September 19, 2011, 05:32:18 PM
...so I made a small square-to-round...
Ok, HOW did you do this!? I have just such an issue for a planned build, and I've been dreading wet-sculpting the trunking out of milliput. Any tips would be greatly appreciated!
Looking great so far, by the way - I love the way you joined the Eagle and Tornado parts. :thumbsup:
Quote from: pyro-manic on September 19, 2011, 11:54:43 PM
Thanks Alun ---  I worked it out in my AutoCad but I did find this on the internet which is really quick (and neat) --
http://www.sheetmetalguy.com/transition.htm
Just follow the instructions and it will spit out a development for you.  When the save menu pops up, browse for a directory that you have on your computer and save it there. Then change the *.txt to *.dxf.
Once you've done that send it to me (by PM) and I'll convert it into a jpeg using my autocad program.  Or just tell me what the sizes are and I'll quickly do it for you.
Basically, what you do is work out a flat development like this
Then after cutting the shape out, carefully bend along the lines in the corners using some long nose plyers. Like this --
BTW, the more segments in the corners (that's all the lines) the smoother the corner becomes, so less sanding.
Robert
Supertom
Y'know, after all this is said and done you might want to build up a Yak-141 as a comparison.
Quote from: Supertom on September 20, 2011, 07:22:21 AM
;D
I might -- but probably won't.  As I don't really like Russian aircraft (or German, or Japanese, or Italian, or ---)   :lol:
Here's a comparison between the GR.5/7 fan front and duct with the one I'm building,
Quite a bit bigger, which is what I was expecting considering that the GR.5 had 23,500 lbs of thrust and this MD one would have 40,000 lbs+.
I decided to cut the wings off the 1/100 F-15 just to see what I'm up against, and I don't think I have to look anywhere else for wings, they actually look about right.
And the aircraft won't be much bigger than a Harrier ---
Hope you have/can-make another set of fan blades! :-\
This is looking great & I'd hate to see knackered fans spoil the look. :thumbsup:
Quote from: Old Wombat on September 21, 2011, 03:00:40 AM
I know I have another around somewhere (IIRC they're a Braz 1/144 fan fronts for a 777) but do you think I can find it --  :banghead:
But I think if I strategically place the broken ones in certain areas, you'll have a hard time seeing them (that's as long as I don't break anymore I guess ---  :-X  )
That's alot of parts to make one aeroplane.....I like it !
Silverfox
Amazing stuff! I'll be watching this closely, especially for ideas on how to model things in future!
Love the work you've done so far, and the concept behind it too.
