Mid fuselage propellors
Started by Caveman, November 04, 2011, 10:20:08 AM
Quote from: Mr.Creak on November 06, 2011, 06:31:46 PM
That said, I'd have thought that a pure pusher type would have been preferable from an engineering (structural) point of view.
Or a conventional tractor type.
Quote from: GTX on November 07, 2011, 01:31:30 AM
Naaaaah, that'd be just silly! Who'd want to put a propeller on the front;D ;) ;D ;)
Caveman
You can get a significant drag reduction by moving the main wing out of the propwash. You loose a significant amount of control authority by moving the tail out of the propwash. I guess it is an attempt at combining the best bits of tractor and pusher configs... Id have swapped the engine and pilot round though.
secretprojects forum migrant
redstar72
Do you know the Belyaev EI (I-370) project?
Best regards,
Soviet Aviation enthusiast
redstar72
Quote from: NARSES2 on November 07, 2011, 07:29:04 AM
Interesting wing planform  :thumbsup:
Yes, it's Belyaev! This is from the man who invented "butterfly wing" and designed the DB-LK!
Some more of his work:
Best regards,
Jschmus
raafif
Quote from: Jschmus on November 07, 2011, 03:23:32 PM
Would Heinkel's VTOL paper projects fit in here, the Wespe and the Lerche?
Yes ..... but they're too sensible !  ;D
Quote from: redstar72 on November 07, 2011, 09:38:10 AM
Unicraft do a kit of something like the twin engined one I think ?
Interesting designs
RussC
Quote from: redstar72 on November 07, 2011, 07:14:28 AM
What a graceful configuration.  :mellow:
RussC
   Yes, this design is getting into flying wing country and was a lot like the design of the Avianito Khai -3
  http://dieselpunks.blogspot.com/2010/07/little-wing-soviet-style.html
raafif
this thread begs the question .... just how good/reliable were the coupling joints in the prop-shafts between engine & propeller ??  P-39 pilots were a bit worried about their valuables if something broke :blink:
The Gallaudet mailplanes look rather interesting.  :thumbsup: Shouldn't be too hard to whiff something going in that direction from a WWI aircraft kit.
Caveman
a modern design, a human powered aircraft. Again i think going for minimum drag from the main wing, apparently not using propwash for lift...
http://airglow.propdesigner.co.uk/airglow2.html
