avatar_chrisonord
Inflight refueling probes
Started by chrisonord, November 16, 2011, 05:04:03 PM
Quote from: Old Wombat on November 17, 2011, 09:33:01 PM
Both the ARTS & CARTS systems look overly complicated, to me, & I have to wonder about the reduction in actual fuel carrying capacity using this system.
I'd be inclined to go with a fixed probe or, preferrably, one of the externally mounted fold-out versions.
My thoughs too O.W, plus it would be a less time consuming exercise making and installing a probe on the aircraft, as well as making it that bit more whiffy :blink:
Chris.
The F4D Skyray used a tank with a probe, IIRC the Soviets had a similar tank?  It's not perfect (for instance, if you need to drop the tank, you loose your refuelling capability) , but it's a plug in system that's easier than modifying an aircraft.
Some early F-84Gs had their probes fixed in the nose of a wing tip tank, but I think the 'production' version had them in the wing leading edge at about half span.
