avatar_mkhulu
Panzer IV / M113 kitbash
Started by mkhulu, February 01, 2012, 02:09:08 AM
Quote from: frank2056 on March 03, 2012, 09:28:50 AM
unless you're hiring legless or height challenged drivers.
Reminds me of a thesis I once argued as a joke in a Usenet newsgroup about the utility of using legless tank crew.  It would allow a smaller, much more heavily armoured vehicle to be built as the armoured volume would be appreciably smaller.   As the audience were primarily American, they missed my continual references to how beneficial being "legless" would be to tank crew operations.   Eventually when someone from IIRC South Africa piped up and pointed out the joke they twigged I'd been pulling their legs (another bad pun).    :wacko:
mkhulu
Not much done this past weekend , but did this right now
Ta for the suggestions - I did move the driver's hatch up a wee bit. Main gun clears it , but barely  ;D
The figure is the 1/35 driver from the Tamiya Ambulance kit - resting his behind on some double sided tape  :lol:  ;D
The piece of armour in front of the driver's hatch has been angled - no 90 degree angle  ;) Bottom bit to be cut this afternoon.
PSR will commence at approx 1600 SAST - That's 1400 GMT
Going nowhere slowly
mkhulu
Used Milliput superfine as putty - I kinda like the smell of Milliput  ;D
Will wait about 24h in order to allow putty to cure sufficiently before I partake in sanding  ;D
Some pics :
Driver's Hatch puttied - not sanded
Hull and Driver's hatch - not sanded also not glued together
mkhulu
Glued and then puttied driver's hatch to the tank. Will wait until tomorrow before I do the 'SR in PSR  ;D
mkhulu
PSR again !  ;D
What's the curing time one should allow for Milliput Superfine White ? Temperature dependent ?
Great seeing my 1st whiff slowly taking form  ;D
Quote from: mkhulu on March 07, 2012, 02:47:11 AM
Yes, the warmer the better, but it goes very floppy if you apply too much external heat to it.
I always leave the stuff overnght, by which time it's set like concrete! Always leave a small bit of the mix close to the model so you can check how hard it's gone by prodding it, without touching your PSR work.
Sticky Fingers
Also depends on how thick a layer you applied, I found out.
Your driverstationlocationwhiffination looks real nice, btw! :thumbsup:
I think Rickshaw is still waiting for some to dry out but then he does live in Australia  :banghead: I'm with Kit, leave it over night.
First wiff ? Taking shape really well
Quote from: NARSES2 on March 07, 2012, 07:03:36 AM
Grrrr, I gave up on the superfine.  That batch never dried.  I use the yellow-grey only now.  Along with the Vallejo that you put me onto.  They compliment each other rather well.
mkhulu
#56
Hull PSR finished
Been finding it's quite finicky working with Milliput - but I don't mind
Don't think I will go the PE route with this one - maybe with a later whiff
Different but interesting & coming alog nicely! :thumbsup:
mkhulu
#58
Busy with PSR - nothing worthy of posting a piccie
Might have found an excuse for breaking my "do-not-buy-anymore-kits-until-you've-finished-one" promise
Need to buy some stuff at the Big H for this build , and while shopping I might as well buy some kits to feed the stash .... ;D
Quote from: mkhulu on March 12, 2012, 05:48:33 AM
To use one of my daughter's (she's the Best Air Traffic Controller in the RAF, not many people know that.... ;)) favourite phrases 'It would be rude not to'.....  ;D
