DH Beaver Torpedo Bomber
Started by tigercat, February 06, 2012, 11:32:06 PM
tigercat
Presumably bush planes such as the Beaver and the Norseman with their STOL capacity would work well as carrier aircraft. With their passenger capacity they'd make good Carrier onboard delivery aircraft but could the Beaver also double as a Torpedo bomber?
Sticky Fingers
Maybe with a Very Small & Light Torpedo, such as the Mk54?
The top speed and rate of climb (255 kph / 5.2 meters per second) of a Beaver is about half that of what a Grumman Avanger could produce 442 kph / 10.5 meters per second). Hanging a 1000 kg explosive fish underneath doesn't sound like a good idea to me.
Then again, I know about as much about torpedo bombers as I do about, oooowwwwhhhh.... most things, so I could be the most wrongest person in the history of wrongness.
tigercat
hmm back to mthe drawing board. What about if you stuck Pegasus off the Swordfish on the front.
If it's an actual Beaver conversion your looking at, you'd want some bigger like Twin Wasp at least.  At the time the DHC-2 was coming online you've got aircraft like the S-2 Tracker, Breguet Alize & Fairey Gannet in development.  Larger & much more capability than you would get out of the Beaver airframe.  However, there's a way in.  The Short Seamew was designed as a lightweight anti-submarine aircraft.  It didn't pan out, but what if Navies had gone for the lightweight ASW approach?  You might find some low-cost derivative designs.  Swap the engine for a larger radial, or pereferably a turboprop like the dart or single Mamba, add in a weapons bay or a recess for a fish.  Not ideal but it if your a cash strapped Navy it might be your only option.
If your looking at the Beaver as a basis for a kitbashed torpedo bomber, then using Swordfish components might be possible, going for something along the lines of the Fairey Albacore maybe?
Quote from: tigercat on February 07, 2012, 03:36:37 AM
Why not just use a Swordfish with improved high-lift devices on the wings?  Slots, flaps on both top and bottom wing would improve an already excellent STOL performance to something like the Beavers.
tigercat
I was looking at the Beaver and it reminded me of the Albacore and I thought that while it was a post war aircraft it wasn't that far post war that it couldn't have been designed 4 or 5 years earlier so what about turning it into an Albacore alternative.
I will add the high lift Swordfish to my list of Swordfish plans
I am currently developing a Mercury & Kestrel powered Swordfish  plus one with an engine from the spares box that I believe was off a Do 217 must check what it was which looks very He 51 ish   Also I am grafting Swordfish onto a Heyford bwahaahhhaa.
Quote from: rickshaw on February 07, 2012, 03:50:07 AM
Fiesler developed something pretty much like that for the Graf Zeppelin: the Fi-167 Imagine an in-line engined Swordfish with two sets of scaled-up Storch wings with ALL the toys on them.... :blink:
http://en.wikipedia.org/wiki/Fieseler_Fi_167
"One notable demonstration showed the type's excellent low speed performance when Fiesler himself sank the Fi 167 from 9,800 ft. to 100 ft. while remaining stationary over one spot while retaining full control."  :blink:
From Here
tigercat
I recently saw a Storch at Duxford and when it flew into the wind it was practically hovering.
Cross a Beaver with the Beech Model 24 proposal and turn that into a torpedo bomber:
;D
Bill TGH
cheers
Bill TGH
{..its all about completion... not perfection }
_________________
Wanted - 1 Kidney,
call Sue Melvin, Living Donor Coordinator, Saint John Regional Hospital
Aircav
Got hold of the Beaver Parts Catalogue and I knew that it could be fitted with wing pylons but I didn't know about the fuselage pylon, TORPEDO AWAY!!
Sir Sydney Camm
Vertical Airscrew SIG Leader
