avatar_Spey_Phantom
WHIF's found in Magazines/books
Started by Spey_Phantom, February 27, 2012, 10:32:23 AM
#210
Oh, cool! Thanks, Flyer - I'll have a peruse!  :thumbsup: :thumbsup:
Later:
YESS!! Those will work, and there's enough material in a lot of them to reshape the blades and cut the diameter down to something more manageable.  :thumbsup: :thumbsup:
Thanks for that, Flyer - have a Pat on the Back - or even two, I'm in a generous mood (takem while you can gettem, it don't happen that often with me...  ;D ;) )
Thanks Brad F.  That website looks to be a great resource.
Scotaidh
Quote from: Rick Lowe on February 23, 2019, 05:14:22 PM
Later:
And - there's these:
$6.35 ea
EDF Ducted Fan Unit 6Blade 2.75inch 70mm
Blade Diameter: 68.3mm / 2.68inch
Outer Case Diameter: 73mm
Wall Thickness: 1.53mm
EDF Length: 59mm
Front Shroud Diameter: 83mm
Motor Mount Holes: (from 18mm & 22mm)
Blade Type: 6
Shaft Size: 4mm
This EDF will take a motor with a maximum diameter of 28mm.(see related items)
Made from high strength reinforced plastic.
Those ducted fans look very useful, I think I will look in to some of those
#214
That's even better, is it from the same site?
Never mind, I see it is... should have looked better!
Thanks, I might have to revisit and spend more money...  ;D
They are almost perfect for what I have in mind.
Stumbled upon this...
Did Batman change sides? And I find the exhaust stubs (???) under the cockpit quite interesting!  :o
Quote from: Dizzyfugu on March 25, 2019, 09:03:08 AM
...and that explains a lot.  :wacko:
What exhaust stubs Jim ? ah! now I see them ---- looking in the wrong place
If they are exhaust stubs, and yes they do look like some, then why does it need them ? Or am I missing something ?
Perhaps it works like the Caproni-Campini, with a piston engine driving the compressor?
Quote from: PR19_Kit on March 26, 2019, 07:59:26 AM
Didn't think of that
In the cartoon book "Economix" explaining economy, I have seen several drawings of aircraft, not completely realistic nor crazy but somewhere in between:
(Ju-87, MiG-15, Super-Constellation, DC-10)
dumaniac
Perhaps - thinking laterally on a what-if site, the shark teeth are just painted on and there is no air intake at the front (in the teeth). The - your - eyes see what they want to see and the black is not an air intake.
Then - the exhaust stubs are from a cooling device or compressor for a nuclear propulsion unit. Such an engine would explain why this jet was such an opponent. Simple really.
Took awhile to spot the exhaust stubs here as well !
