Pan Am Concorde
Started by giraffeboy, April 05, 2012, 12:25:10 PM
giraffeboy
A while back, I got a job lot of built kits (all in "glue bomb" state for a tenner of of eBay. One of them, was an early release of the airfix Concorde, the one which was based on the prototypes. I intended to rebuild it, however, it was in such a bad state (warped and glue everywhere) that i gave up.
However, yesterday, I came across the following image :
I've always liked the old style shorter tail, and when i had a look through my kit stash, what did I find? An unbuilt Airfix Concorde, and a the model described earlier. Upon examination, the tail wasn't in too bad condition, compared to the rest of the model.
I then found this, left over from a revell SST kit, which i built in BA livery, leaving these redundant.
So, without further ado, I started. First, I had to cut off the tail sections from each kit, along the line parallel to the bit where the elevons attach to the wing (frame 72) :
After alot of sanding and filling, here is what it looks like:
I used the old nozzles from the glue bomb kit, and added them to the new engine nacelles :
And then, to make this a real "whif" i decide to change the main landing gear. I took the side strut from the normal one and glued it onto the new gear, and the result was that they were the exact same length - spooky eh?
Now, all I have to do is paint a few things such as the landing gear etc, and I'm done! Phew, never done such a quick build !
Veeeery interesting!  ;D
You've essentially modelled Concorde 101, the pre-production prototype now at Duxford, as it's the only Concorde with the short tail and the production type visor and windscreen.
Where did the triple axle main gear from, a 777 perhaps?
giraffeboy
Oh yeah, forgot about that! I guess it does quite a bit :)
I think that mine will have a slightly longer forward fuselage, because that was one of the updates to the design of G-AXDN, along with the revised tail.
I don't have a clue where the 3 axle gear came from, I'm afraid, it was in a large box of spares i bought from an antiques market.
giraffeboy
Here's a photo update. Wings have been attached, and landing gear dry fitted.
Vulcan7
