avatar_Weaver
English Electric P.7D
Started by Weaver, April 07, 2012, 02:45:38 PM
See if you can find the Su-9/11 Fishpot as those are bigger diameter than the the SU-7
Really? I thought the Su-9 was "just" an Su-7 with a delta wing, while the Su-11 is an Su-9 with a straight (rather than tapered) nose to accomodate a bigger radar.
As an aside, there were a Leoman Su-9 and Su-11 on a stall at Cosford which I ummed and arhhed about for a while.....
Quote from: Weaver on April 11, 2012, 04:41:40 AM
basically you're right.  The Leoman Su-11 is a little bit shorter than the VEB Su-7 but has a fuselage roughly the same diameter, at its widest.
albeback
I like this! Anything Lightning shaped gets my vote!! :o ;D.
In fact, since seeing this build, I've been giving serious thought to combining my KP 1/48 SU-7 fuselage with the cockpit ( interior/ejection seat) , spine, tail assembly & wings from an Airfix 1/48 Lightning F2!
It should be feasible to graft the Lightning belly tank on to the SU-7 as well! :-\
Hmmmmmmm!
Mr Ten
If I saw this back in the day I failed to comment.
Why? I have no idea because it is a wonderfully realised concept & it looks brilliant! :thumbsup:
That looks absolutely gorgeous!! I like that more than i like the real one! :thumbsup: :thumbsup:
It will be interesting to compare the two models once they are done  :thumbsup:
Doug K
Never was a fan of the Lightning, but that is rather beautiful
