avatar_comrade harps
Academy's Hellcat rockets?
Started by comrade harps, April 07, 2012, 04:47:08 PM
comrade harps
I've got the rockets from the Academy F6F Hellcat kit. I'm thinking of using them on an A-26 Invader, but the warheads are unsual and I haven't found a convincing explanation of this on the web. You can see them loaded on this model http://www.aircraftresourcecenter.com/rh/articles.php?id=1071 and this one http://allaircraftsimulations.com/forum/viewtopic.php?f=102&t=31060&start=0 and on this one too: http://airplanesandmore.com/proddetail.php?prod=HA1103&PHPSESSID=c7a6d02d58a01cf6d48435bdc7b6db98
True, I've got illustrations of Hellcats with 5 inch HVARs displaying the bulbous warhead (somewhat like the British 60lb RP3 or the Korean War era RPG-style RAM anti-tank warheads, but less streamlined). I've seen these bulbous warheads referred to as an amour-piercing warhead, but none of the more detailed HVAR descriptions mention such a warhead used in WW2.
Maybe the rockets are incorrect, or are really 3.5 inch FFARs? Then there's the 5 inch FFAR, used as an interim weapon before the 5 inch HVAR. Or are they of a real type of warhead used by USN Hellcats during WW2? I dunno.
While we're at it, if they aren't real, what could they be in a what-if world?
Any help appreciated.
Whatever.
Are they just a poor attempt at the British 3" RP?
Sensemann
It is a 5-Inch Forward Firing Aircraft Rocket developed by the U.S. Navy and introduced in 1943. The 3.5-inch diameter nonexplosive warhead they were using as an aircraft-launched ASW rocket was accurate enough for surface ships and land targets but this required an explosive warhead. A 5-inch anti-aircraft shell was attached to the 3.5-inch rocket motor creating the 5-Inch FFAR and entered service in December 1943. Performance was limited because of the increased weight and the High Velocity Aircraft Rocket was developed to fix this.
comrade harps
So, you think it's a 5 inch FFAR, which I had as one of my options?
I'm leaning towards this as the solution to the puzzle.
Ta.
Whatever.
Sensemann
I guarantee that's what it is. Only the U.S. Navy used those during WW II. Like I said before it was a 3.5 in rocket with a 5 in AAA shell attached to it.
