avatar_pyro-manic
De Havilland Fireball
Started by pyro-manic, April 11, 2012, 04:31:22 PM
Daryl J.
gofy
Which kits (scale, manufacturer etc) :unsure:
I LOOOOOOOOVE this build!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :wub: :wub:
In my opinion, British, Canadian, or USAF markings make things look so much better...
Imagine....Pyro building a Fireball  :thumbsup:
That thing does look right....looking forward to seeing where you take it.
NIce, although I'd use leading edge radiators to sort out the wings from where the nacelles were.  In addition, I'd move the cockpit about a cm further forward.  Pilot view over the nose would be horrendous.
TallEng
WOW! That looks promising, Lets see now DH88 Comet, and a Merlin up front, long pointy wings,
= High Altitude, or record breaking long range flight? who knows....
Can't wait to see what happens next :thumbsup:
(looks like the holes for the engine nacelles will make mighty fine radiator inlets, And cockpits on Merlin engined Aircraft are always too far back! ;D)
Keith(wishing he'd thought of 'that', what ever 'that' will be)
I've a Novo one that I was planning on doing as a PR machine at some stage.  Although on reflection, the Frog one was always the better kit, so it may be better to use an Airfix one and keep the nice new decals for the Novo kit.
Vulcan7
Now this I am realy looking forward to.
Do not keep us waiting too long Alun.
Jim
We've seen a few single engined aircraft whiffed into twins before now, but I don't think we've seen the opposite.
Radical, and good thinking. Looking forward to the final result.  :thumbsup:
Thanks, everyone - I will try not to disappoint! The nacelle "stumps" will indeed be turned into radiators, and the over-the-nose view will hopefully not be too bad, as the new landing gear will be a bit shorter so it's "stance" will not be so nose-high.
Your u/c stance and height is dictated by the prop arc - when the tail liftson take off, you don't want to be pecking the ground. Witness the number of Seafires written off by doing just that on landing and take off.
Yep. But though the Spit prop is much bigger, it's mounted higher up, so there's a tiny bit more clearance compared to the original props. Means the u/c can be a tiny bit shorter. It's not a huge amount, but it will help.
And now that I think about it, I have one of the undersized props from the new Airfix Hurricane II around somewhere - I might try that and see how it looks, to give me a bit more leeway...
Pics of my dH Dolphin as seen at Telford to follow.  A Merlin Comet can be done, chaps.
